Music on Hold issue
Discussion in '3CX Phone System - General' started by pc75, Sep 20, 2016.
  1. pc75
    Aug 5, 2016
    6
    Afternoon all, and thank you for anyone that is able to assist.
    We have set up 3CX, and have 2 Yealink T48G phones, with current firmware on them. If I call in to the PBX from an outside number, and put the call on hold, only silence is heard.
    If I call from one of the Yealink phones to the extension of the other phone, and put that call on hold, we hear our custom music.
    From the music on hold page in 3CX management console, I can make the system ring an extension and play the music just fine.
    I believe the file is mono, 8Kb, as it's playing properly almost everywhere but where we must have it working (external calls).
    Would anyone be able to point me in the right direction here please?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Hi there,
    Please try the following and let us know if this works:
    Navigate to your trunk>> options >>Advanced and disable Supports Re-invite and Support Replaces.
    Make sure PBX delivers audio is enabled.
    Save the changes by clicking ok and try again
  3. pc75
    Aug 5, 2016
    6
    Morning Yiannis, and sorry for the delay in reply!
    I have tested the settings as you detail above, and the music on hold is now working perfectly :)
    Many thanks for your help!
  4. ewild
    Oct 26, 2013
    I have the same problem, but the solution you mention to me does not work for me.
    Only external calls can´t hear the MOH.
    My 3cx Version is PBX 15.5.1694.0
