Music on Hold not Working
Discussion in '3CX Phone System - General' started by Jamie Snapp, Nov 28, 2017.
  1. Jamie Snapp
    Feb 20, 2017
    10
    I have added 3 wave file to a music on hold playlist. However it does not work. Is there something special I have to do to get this working? I have selected the playlist for call parking however when I park myself or a caller all we hear is dead air.
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
    What version of 3CX ?
    What format are the files, as they have to be Format WAV (PCM, 8 kHz, 16 bit, Mono, Max size: 100MB)
    Do they play correctly on another machine ?
    #2 Saqqara, Nov 28, 2017
  3. vizualpro
    vizualpro New Member
    Jul 9, 2016
    115
    23
  4. Jamie Snapp
    Feb 20, 2017
    10
    The files are wav files in the correct format. I can have each of the 3 files play independently if I take them out of the play list and add them to General MOH.
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @Jamie Snapp
    Are you using windows or Linux PBX? Is this a clean install or an upgrade?
  6. Jamie Snapp
    Feb 20, 2017
    10
    Windows PBX and Clean install
  7. viraltechnology
    Mar 22, 2015
    39
    6
    thats interesting, i will have to take my files out of the playlists and see if they will play as well.
  8. YiannisH_3CX
    May 10, 2016
    7,400
    535
    Navigate to Dashboard / Services and check if the 3CX PhoneSystem 01 AudioProvider service is present and started. Also have you tried restarting the Media Server service?
  9. Jamie Snapp
    Feb 20, 2017
    10
    This service is not present.
  10. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    Jamie you have to do a backup, uninstall, re-install, re-load backup. The playlist feature was added in v15.5 and if you did an upgrade of v15 from the management console to v15.5 it won't add the new service to 3CX. The only way to make the playlist feature work on windows that was started with v15 and upgraded to v15.5 is a re-install so it will add the new service that manages the playlist feature.
    https://www.3cx.com/community/threads/v15-5-moh-playlists-not-working.49385/
    YiannisH_3CX likes this.
