Music On Hold RTP Stream
Discussion in '3CX Phone System - General' started by auto_emocion, Feb 3, 2010.
  1. auto_emocion
    Feb 3, 2010
    7
    I have this wierd problem.
    I have 2 Grandstream GXP2000, when I dial each other on the ext and press HOLD button, i hear no music.
    extracted from log is behaviour of HOLD button press and release.
    17:24:24.015 [MS104000] C:6.2: (ACTIVE) RTP stream to 129.200.7.14:5040 restored.
    17:24:23.234 [MS004000] C:6.2: (ACTIVE): Can't send RTP stream to 0.0.0.0:5040 destination unreachable
    17:24:22.484 [MS104000] C:6.2: (ACTIVE) RTP stream to 129.200.7.14:5040 restored.
    17:24:21.484 [MS004000] C:6.2: (ACTIVE): Can't send RTP stream to 0.0.0.0:5040 destination unreachable
    17:24:20.593 [MS104000] C:6.2: (ACTIVE) RTP stream to 129.200.7.14:5040 restored.
    17:24:15.171 [MS004000] C:6.2: (ACTIVE): Can't send RTP stream to 0.0.0.0:5040 destination unreachable
    17:24:14.218 [MS104000] C:6.1: (ACTIVE) RTP stream to 129.200.7.3:5066 restored.
    17:24:09.468 [MS004000] C:6.1: (ACTIVE): Can't send RTP stream to 0.0.0.0:5066 destination unreachable
    Can anyone help.?
    Thanks.
  2. auto_emocion
    Feb 3, 2010
    7
    I've found this on the GXP-2000 configuration guide.
    NOTE: Music on Hold will not be played internally when a call involving a Grandstream phone is placed on hold. To fix this behavior you will need to access the 3CX Management console, Edit Extension, click on 'Other' tab and perform the following changes:
    Uncheck Supports Re-Invite (This will automatically disable 'Replaces')
    Check PBX Delivers Audio
    WIll try it out.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,127
    152
    This will fix the problem for sure.
    Grandstream have promised us a fix for this in the near future.
