Music on hold stops after few seconds
Discussion in '3CX Phone System - General' started by JoostGeelen, Oct 26, 2016.
  1. JoostGeelen
    Aug 31, 2016
    Hello!
    The music on hold stops after a few seconds. When the caller has made his choice in the Digital receptionist menu, the music starts then stops after a few seconds and then the caller is waiting with no sound on the background. I use v15 service pack 1 and the sound dit work before.
    Can anyone help me with this problem?
    With kind regards,
    Joost
    11,126
    330
    Does it always stop in exactly the same place (time)? Have you tried another audio file?
  3. JoostGeelen
    Aug 31, 2016
    Yes at the same time when i try another audio file it stops after exactly the same time.
  4. leejor
    11,126
    330
    Is there anything in the 3CX log (you might have to use the verbose setting), when this happens?
    When did this start, when you initially went to 15, or after the application of "something"?
