music on hold: using mp3 playlist
Discussion in '3CX Phone System - General' started by jacky18, Sep 15, 2008.
  1. jacky18
    Feb 16, 2008
    16
    Hi all
    Is there a way we can make the 3cx to broadcast like a playlist rather than a single looping music?
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    You cannot do a play list but you can merge multiple files into one and then play that one file.
    regards
  3. jacky18
    Feb 16, 2008
    16
    Thanks for your help. :)
