Music on Hold ( V11 )
Discussion in '3CX Phone System - General' started by donbru01, Jun 5, 2012.
  1. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Two question for music on hold :
    1. when i place call in "transfer" ( external caller hear Music on Hold from start ) , when i press button Parking SP0-SP1 Music Return Play from Start is correctly ?
    2. I press CONF , external caller not hear any Music on Hold , when i finished digit internal extension , external caller hear Music on Hold , is correctly ?
    thanx
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    Depends how you have it set up. If you are using Streaming or Line In in v11 then music point is where the device or playlist is.
    Otherwise - I think the wav method always starts from beginning.
  3. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    yes you have right ! I use wav file .
    But when
    1. i put on hold via Transfert , call is on Hold ! when i press SP0 call remain on Hold ! Because MOH restart , must be continued .
    Example MOH is file 60 second Music , i press Transfert , MOH Start , 1sec 2 sec .... at 10sec i press SP0 ( BLF ) that music restart 1sec 2 sec ....
    2. in teory CONF place call on Hold ..... ( i suppose ) , why MOH not start
  4. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    So are you saying conference callers hear no music on hold?
    I'm not sure if V11 is the smae as V10 but....
    Do you have a .WAV file for the conference calls?
    Look under Settings, Advanced then the Conferencing Tab.
    Here you can select a music on hold file to play for conference calls.
  5. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Sorry , no problem with conferencing on "n" extension , it work better .
    Problem is when i use normal 3Way Conference :
    1. user "A" on call with user "B"
    2. user "A" make CONF ( button ) ---- user "B" no hear MoH , but it is on hold
    3. user "A" make a 3 digit to other user "C"
    4. user "C" ringing ---- user "B" hear MOH
    5. user "A" press CONF (button) , ABC on call conference
    My problem is , why during step 2 user "B" not hear MOH??
  6. efounco
    efounco New Member
    Sep 28, 2011
    148
    I just tried this scenario with version 11b and as soon as I hit [conf] the caller is put on hold and they can hear music.
    Which phones/firmware version are you using?
    I'm guessing the issue has to do with your phone's firmware because we are using Cisco SPA-504G phones here. Prior to firmware version 7.4.9a, when you pressed either [conf] or [bxfer] the caller was put on hold but couldn't hear any music.
  7. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Good answer Efounco , i haven't think that problem occurs from Phone !!!
    I use Grandstream 2100 release 1.7.0.60 latest ...
    I haven't in this moment other phone to replicate it , but your answer suggest me to investigate towards phone
    Thanx soo much for your help
    Bruno
