music on hold w/Polycom 330
Discussion in '3CX Phone System - General' started by stillabdul, Mar 13, 2009.
  1. stillabdul
    Mar 13, 2009
    8
    I have 3cx running and a Polycom 330 IP phone. I uploaded a moh file, and when i put someone on hold from the phone, the moh doesn't work. If I use the VOIP client, and put a party on hold, the moh works.
    Am I missing some configuration points on the Polycom?
    Thanks.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    Bind the polycom to media server.
    Go to the extension
    Other Tab
    Check - PBX Delivers Audio
  3. stillabdul
    Mar 13, 2009
    8
    Thanks nickybrg,
    That worked! Awesome!
