music on hold wave input device on 3cx preview 14?
Discussion in 'Windows' started by hank.smith966, Jun 26, 2015.
  1. hank.smith966
    Jun 26, 2015
    Hello on your 3cx pbx version 12 you have a music on hold feature that allows one to use there sound card for music on hold
    if memory serves its music wave input
    anyways on v14 preview I am not seeing this feature did it get removed from 14?
    hank
  2. Charles_3CX
    Charles_3CX New Member
    3CX Support
    Jul 6, 2015
    114
    Hi, That's correct, Music on hold must be a wave file. There is no option to input from sound card as direct audio input.
