Music on hold won
Discussion in '3CX Phone System - General' started by tcgmuc, Mar 18, 2007.
  1. tcgmuc
    Mar 14, 2007
    59
    Hi 3CX-Team,
    becaus of my now solved problem with dial-out numbers I installed the actual Version of 3CX. Now the music on hold won
  2. me
    me
    Mar 7, 2007
    9
  3. vadim
    Aug 17, 2006
    9
    Yes. It is the same. The simples fix - copy from .../bin to ...data/http/prompts/
    I'll try to find reason why there is not onhold.wav in ...data/http/prompts
  4. tcgmuc
    Mar 14, 2007
    59
    Hi Me, Vadim,
    the problem is still there ... the file was in the correct directory .... so I deleted the hole dir and set up the file again via config-menu and it was copied correct in ..\data\http\prompts ... but it won
  5. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Please, check if your devices support re-INVITE. To get music-on-hold they should either support reINVITE, or be bound to Media Server.
  6. tcgmuc
    Mar 14, 2007
    59
    Hi Archie,
    this feature worked before in Version RC2, but now in RC3 it won
  7. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    Do you have and hard/soft phones handy ? so we can see if the is an installation issue or a device compatability issue.
    I know it worked before, but maybe the phone is not liking some new behaviour (or configuration)
  8. tcgmuc
    Mar 14, 2007
    59
    Hi Support-Team,
    so this are my phones:
    2 x Linksys SPA941, 4 Lines active
    1 x Siemens S450 IP
    1 x Linksys WIP330
    I tried to disconnect all phones except one 941 and tried it and it won
  9. archie
    3CX Support
    Aug 18, 2006
    1,299
    Please, describe in details your settings for 941, including advanced options.
  10. tcgmuc
    Mar 14, 2007
    59
    Hi Archie,
    to post the whole config is a little bit too much I think, but if you need special details, I can post that .... I tried something else before.
    I called from a registered phone over an ISDN-Number that is routet to SIPGATE Phone-Nr. I pressed XFer and no music was there. Same procedure, but I called from inside directly our SIPGATE Phone-Nr. and than XFer ... voil
  11. archie
    3CX Support
    Aug 18, 2006
    1,299
    No, I don't need settings OF the device (honestly, I don't even know what is it? gateway? sip-phone?) Only settings you've done for 3CX configuration about this device, including advanced options, it this is a gateway device.
  12. tcgmuc
    Mar 14, 2007
    59
    Hi Archie,
    so first step ... the configuration of the Linksys SPA941 Phone ist the same as some of you wrote it in your FAQ of "Configuring a Linksys SPA-921 with 3CX Phone System".
    The config. for the SPA941 in 3CX will I post next few hours.
    Greethings,
    Michael.
  13. archie
    3CX Support
    Aug 18, 2006
    1,299
    That FAQ fully describes how to configure the phone, but I'm asking about configuration settings for that phone in 3CX itself.
    To tell me that settings, go to Edit Extension page, and than press 'Show advanced options' button, and tell me the settings of four check-boxes in there. If your phone is registering ok, I don't need other options.
  14. tcgmuc
    Mar 14, 2007
    59
    Hi Archie,
    sorry for delay, but here we go ....
    Device is External --> unchecked
    Bind to Media Server --> unchecked
    Supports Re-Invite --> checked
    Supports 'Replaces' header --> unchecked
    I also tested "Bind to Media Server" with checked ... same problem
    Hope this will help to find the error ...
    Greethings and thanks for help,
    Michael.
  15. tcgmuc
    Mar 14, 2007
    59
    Hi Archie,
    could you find out anything about this error ?
    Greethings,
    Michael.
  16. archie
    3CX Support
    Aug 18, 2006
    1,299
    I think the problem is in the way SIPGATE processes 'Transfer' command. Or, possibly, even ISDN gateway may interfere in this situation. We can not play music on hold until we get corresponding request. So, it looks like in some cases SIPGATE doesn't send us such a request.
    For more thorough investigation we need logs and, preferrably, traffic captures for each case. We will appreciate if you can provide us with it.
  17. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Hello...There is a very easy workaround this. If you to create an extension which you will never register, and forward the ring group to the voicemail of that extension.
  18. tcgmuc
    Mar 14, 2007
    59
    Hi there,
    this ist the workaraound that I use for the moment, but it would be nice, that Ring-Groups will get their own Voice-Box.
    Thanks for help,
    Michael.
  19. tcgmuc
    Mar 14, 2007
    59
    Hi there,
    my "old" Problem with Music on hold is coming up again ... if I try the following the logfile says something ....
    On one line I activated "bind to media server" and the log shows the following entry on a call from outside, if I put the caller on hold:
    00:44:26.132 StratLink::eek:nHangUp Call(C:C): got Hang-Up from Ln:10003@sipgate_geheim; reason: BYE
    00:44:15.960 ??: from 'demuntcgwsmp01:0/MediaServer':EP 00000013@(ACTIVE): Can't send RTP stream to 0.0.0.0:16422 destination unreachable
    00:43:53.741 ??: from 'demuntcgwsmp01:0/MediaServer':EP 00000013@(ACTIVE): RTP stream to 10.0.1.50:16422 restored.
    00:43:43.913 ??: from 'demuntcgwsmp01:0/MediaServer':EP 00000013@(ACTIVE): Can't send RTP stream to 0.0.0.0:16422 destination unreachable
    00:43:36.897 CallLegImpl::eek:nConnected Established media channel for Ext.103: remote=10.0.1.50:16422; local=10.0.1.100:7036
    00:43:36.897 StratInOut::eek:nConnected Call from Ln:10003@sipgate_geheim to Ext.103 is established
    00:43:36.897 CallLegImpl::eek:nConnected Established media channel for Ln:10003@sipgate_geheim: remote=217.10.68.72:47770; local=10.0.1.100:7034
    00:43:31.929 CallConf::eek:nIncoming Incoming call from Ln:10003@sipgate_geheim to sip:4989xxxxxxxx@sipgate.net
    Now I think the entry destination unreachable ist the problem, but how to correct that ?
    Greethings,
    Michael.
  20. tcgmuc
    Mar 14, 2007
    59
    Hi there,
    this ist part of the tracelog, if I call from my mobile to 3CX an put the mobile on hold and take it back from hold .... no music was played.
    01:23:24.046|TransactionState.cxx(470)|Trace5|Resip|>>: discarding stray response: SipResp: 180 tid=6d3a0f610758954b cseq=INVITE contact=300@10.0.1.53:5060 / 1 from(wire)
    01:23:33.718|.\Endpoint.cpp(75)|Trace5|Endpoint|Endpoint::findSource: No Remote-Party-ID header found
    01:23:33.718|.\Endpoint.cpp(81)|Trace5|Endpoint|Endpoint::findSource: DBCfgDevice got from database
    01:23:33.734|.\Endpoint.cpp(84)|Trace5|Endpoint|Endpoint::findSource: DBCfgExtLineSet got from database
    01:23:33.734|.\Endpoint.cpp(88)|Trace5|Endpoint|Endpoint::findSource: DBCfgDevice invalid or no host in contact is used
    01:23:33.734|.\Endpoint.cpp(91)|Trace5|Endpoint|Endpoint::findSource: Device Is cleared
    01:23:33.734|.\Endpoint.cpp(95)|Trace5|Endpoint|Endpoint::findSource: Lines Is here
    01:23:33.750|.\Endpoint.cpp(102)|Trace5|Endpoint|Endpoint::findSource: Only one lines is here
    01:23:33.750|.\Endpoint.cpp(105)|Trace5|Endpoint|Endpoint::findSource: Settings for caller is found: CfgExtLine:10003
    01:23:33.750|DialogUsageManager.cxx(1190)|Trace5|Resip|>>: Got: SipReq: INVITE 1950222e1@10.0.1.100:5060 tid=eb78.d46c7ca6.0 cseq=INVITE contact=0172xxxxxxx@217.10.67.4 / 102 from(wire)
    01:23:33.750|.\CallMgr.cpp(274)|Trace5|CallControl|ADSFactory::createAppDialogSet: Creating ADS for INVITE
    01:23:33.750|.\CallConf.cpp(404)|Trace5|CallControl|CallConf::CallConf: Call created: C:E
    01:23:33.750|.\CallConf.cpp(347)|Trace5|CallControl|CallConf::addCallLeg: Added leg# 1 to call C:E
    01:23:33.750|.\Call.cpp(1116)|Trace5|CallControl|CallLegImpl::CallLegImpl: Leg @L:1@C:e is created
    01:23:33.750|InviteSession.cxx(2046)|Trace5|Resip|>>: Transition UAS_Start -> UAS_Offer
    01:23:33.750|.\ISHandler.cpp(21)|Trace5|CallControl|ISHandler::eek:nNewSession: Incoming: sis=1180;oat=Offer;rl=INVITE sip:1950222e1@10.0.1.100:5060;rinstance=546e812a04581877 SIP/2.0
    01:23:33.750|.\Endpoint.cpp(75)|Trace5|Endpoint|Endpoint::findSource: No Remote-Party-ID header found
    01:23:33.750|.\Endpoint.cpp(81)|Trace5|Endpoint|Endpoint::findSource: DBCfgDevice got from database
    01:23:33.765|.\Endpoint.cpp(84)|Trace5|Endpoint|Endpoint::findSource: DBCfgExtLineSet got from database
    01:23:33.765|.\Endpoint.cpp(88)|Trace5|Endpoint|Endpoint::findSource: DBCfgDevice invalid or no host in contact is used
    01:23:33.765|.\Endpoint.cpp(91)|Trace5|Endpoint|Endpoint::findSource: Device Is cleared
    01:23:33.765|.\Endpoint.cpp(95)|Trace5|Endpoint|Endpoint::findSource: Lines Is here
    01:23:33.765|.\Endpoint.cpp(102)|Trace5|Endpoint|Endpoint::findSource: Only one lines is here
    01:23:33.765|.\Endpoint.cpp(105)|Trace5|Endpoint|Endpoint::findSource: Settings for caller is found: CfgExtLine:10003
    01:23:33.765|.\Call.cpp(89)|Trace5|CallControl|CallLegImpl::eek:nIncoming: Endpoint is built: Ln:10003@sipgate_geheim
    01:23:33.765|.\Call.cpp(458)|Trace5|CallControl|CallLegImpl::initMSEndpoint: Created internal MS endpoint for Ln:10003@sipgate_geheim: addr=10.0.1.100:7042
    01:23:33.765|ServerInviteSession.cxx(91)|Trace5|Resip|>>: UAS_Offer: provisional(100)
    01:23:33.765|InviteSession.cxx(2046)|Trace5|Resip|>>: Transition UAS_Offer -> UAS_EarlyOffer
    01:23:33.765|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend: InviteSession(1180) sends SIP/2.0 100 Trying
    01:23:33.765|.\CallConf.cpp(95)|Log2|CallControl|CallConf::eek:nIncoming: Incoming call from Ln:10003@sipgate_geheim to sip:4989xxxxxxxxxx@sipgate.net
    01:23:33.765|.\CallStrategies.cpp(414)|Trace5|CallManager|StratInOut::initialize: Initialize InOut call strategy
    01:23:33.765|.\ExtLine.cpp(207)|Trace5|Endpoints|ExtLine::getTargetOverride: Look for target override
    01:23:33.781|.\CallTarget.cpp(761)|Trace5|CallManager|CT_GroupRingAll::selectNextTarget: Select new line for outbound call
    01:23:33.796|.\Call.cpp(458)|Trace5|CallControl|CallLegImpl::initMSEndpoint: Created internal MS endpoint for Ext.103: addr=10.0.1.100:7044
    01:23:33.796|.\CallConf.cpp(347)|Trace5|CallControl|CallConf::addCallLeg: Added leg# 2 to call C:E
    01:23:33.796|.\Call.cpp(1116)|Trace5|CallControl|CallLegImpl::CallLegImpl: Leg 103@L:2@C:e is created
    01:23:33.796|.\CallTarget.cpp(772)|Trace5|CallManager|CT_GroupRingAll::selectNextTarget: Extension Ext.103 is choosen for receiving call
    01:23:33.796|.\CallConf.cpp(107)|Trace5|CallControl|CallConf::eek:nIncoming: MediaServer could be used for this call
    01:23:33.796|.\ISHandler.cpp(157)|Trace5|CallControl|ISHandler::eek:nOffer: Offered: is=1180; rl=INVITE sip:1950222e1@10.0.1.100:5060;rinstance=546e812a04581877 SIP/2.0
    01:23:33.796|.\CallStrategies.cpp(604)|Trace5|CallManager|StratInOut::eek:nOffer: InOut: got offer from 10003@L:1@C:e
    01:23:33.796|.\CallEvents.cpp(78)|Trace5||FireStatusEvent: Fire event: Calling; DN 10003
    01:23:33.796|.\CallTarget.cpp(813)|Trace5|CallManager|CT_GroupRingAll::Invite: Placing call to 103@L:2@C:e
    01:23:33.843|DialogUsageManager.cxx(1190)|Trace5|Resip|>>: Got: SipResp: 100 tid=ca2fa85b1239af22 cseq=INVITE / 1 from(wire)
    01:23:33.875|DialogUsageManager.cxx(1190)|Trace5|Resip|>>: Got: SipResp: 180 tid=ca2fa85b1239af22 cseq=INVITE / 1 from(wire)
    01:23:33.875|DialogSet.cxx(702)|Trace5|Resip|>>: Cannot create a dialog, no Contact in 180.
    01:23:33.875|.\CallStrategies.cpp(619)|Trace5|CallManager|StratInOut::eek:nProvisional: InOut: got provisional SIP/2.0 180 Ringing from 103@L:2@C:e
    01:23:33.875|ServerInviteSession.cxx(91)|Trace5|Resip|>>: UAS_EarlyOffer: provisional(180)
    01:23:33.875|InviteSession.cxx(2046)|Trace5|Resip|>>: Transition UAS_EarlyOffer -> UAS_EarlyOffer
    01:23:33.875|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend: InviteSession(1180) sends SIP/2.0 180 Ringing
    01:23:36.437|DialogUsageManager.cxx(1190)|Trace5|Resip|>>: Got: SipResp: 200 tid=ca2fa85b1239af22 cseq=INVITE contact=103@10.0.1.50:5063 / 1 from(wire)
    01:23:36.437|Dialog.cxx(547)|Trace5|Resip|>>: Dialog::dispatch, ignoring stray response: SipResp: 200 tid=ca2fa85b1239af22 cseq=INVITE contact=103@10.0.1.50:5063 / 1 from(wire)
    01:23:36.437|InviteSession.cxx(2046)|Trace5|Resip|>>: Transition UAC_Start -> InviteSession::Connected
    01:23:36.437|InviteSession.cxx(2343)|Trace5|Resip|>>: Sending SipReq: ACK 103@10.0.1.50:5063 tid=e81c5227b6586158 cseq=ACK contact=0172xxxxxxx@10.0.1.100:5060 / 1 from(tu)
    01:23:36.437|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend: InviteSession(1183) sends ACK sip:103@10.0.1.50:5063 SIP/2.0
    01:23:36.437|.\ISHandler.cpp(31)|Trace5|CallControl|ISHandler::eek:nNewSession: Answered: sis=1183;oat=Answer;rl=SIP/2.0 200 OK
    01:23:36.437|.\CallStrategies.cpp(560)|Trace5|CallManager|StratInOut::eek:nAnswered: Call from Ln:10003@sipgate_geheim is answered on Ext.103
    01:23:36.437|.\CallTarget.cpp(825)|Trace5|CallManager|CT_GroupRingAll::answered: Call is accepted on 103@L:2@C:e
    01:23:36.437|.\CallEvents.cpp(78)|Trace5||FireStatusEvent: Fire event: Ringing; DN 103
    01:23:36.437|.\ISHandler.cpp(149)|Trace5|CallControl|ISHandler::eek:nAnswer: Answered: is=1183; rl=SIP/2.0 200 OK
    01:23:36.437|.\CallStrategies.cpp(628)|Trace5|CallManager|StratInOut::eek:nAnswer: InOut: got answer from 103@L:2@C:e
    01:23:36.437|.\Call.cpp(947)|Trace5|CallControl|CallLegImpl::provideAnswer: Provide answer (direct) to 10003@L:1@C:e
    01:23:36.437|ServerInviteSession.cxx(251)|Trace5|Resip|>>: UAS_EarlyOffer: provideAnswer
    01:23:36.437|InviteSession.cxx(2046)|Trace5|Resip|>>: Transition UAS_EarlyOffer -> UAS_EarlyProvidedAnswer
    01:23:36.437|ServerInviteSession.cxx(443)|Trace5|Resip|>>: UAS_EarlyProvidedAnswer: accept(200)
    01:23:36.437|InviteSession.cxx(2046)|Trace5|Resip|>>: Transition UAS_EarlyProvidedAnswer -> UAS_Accepted
    01:23:36.437|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend: InviteSession(1180) sends SIP/2.0 200 OK
    01:23:36.437|.\ISHandler.cpp(74)|Trace5|CallControl|ISHandler::eek:nConnected: ConnectedUAS: is=1180;rl=SIP/2.0 200 OK
    01:23:36.437|.\Call.cpp(177)|Trace5|CallControl|CallLegImpl::eek:nConnected: Connected: 10003@L:1@C:e
    01:23:36.437|.\CallStrategies.cpp(643)|Trace5|CallManager|StratInOut::eek:nConnected: InOut: got Connected from 10003@L:1@C:e
    01:23:36.437|.\Call.cpp(190)|Log2|CallControl|CallLegImpl::eek:nConnected: Established media channel for Ln:10003@sipgate_geheim: remote=217.10.68.74:53374; local=10.0.1.50:16426
    01:23:36.437|.\ISHandler.cpp(65)|Trace5|CallControl|ISHandler::eek:nConnected: ConnectedUAC: cis=1183;rl=SIP/2.0 200 OK
    01:23:36.437|.\Call.cpp(177)|Trace5|CallControl|CallLegImpl::eek:nConnected: Connected: 103@L:2@C:e
    01:23:36.437|.\CallStrategies.cpp(643)|Trace5|CallManager|StratInOut::eek:nConnected: InOut: got Connected from 103@L:2@C:e
    01:23:36.437|.\CallStrategies.cpp(664)|Log2|CallManager|StratInOut::eek:nConnected: Call from Ln:10003@sipgate_geheim to Ext.103 is established
    01:23:36.437|.\CallEvents.cpp(78)|Trace5||FireStatusEvent: Fire event: Connected; DN 10003
    01:23:36.437|.\CallEvents.cpp(78)|Trace5||FireStatusEvent: Fire event: Connected; DN 103
    01:23:36.437|.\CallConf.cpp(365)|Trace5|CallControl|CallConf::changeStrategy: Call C:E changes strategy CS.InOut to CS.Link
    01:23:36.437|.\CallStrategies.cpp(846)|Trace5|CallManager|StratInOut::~StratInOut: InOut: strategy is terminated
    01:23:36.437|.\Call.cpp(190)|Log2|CallControl|CallLegImpl::eek:nConnected: Established media channel for Ext.103: remote=10.0.1.50:16426; local=217.10.68.74:53374
    01:23:36.437|.\Call.cpp(197)|Trace5|CallControl|CallLegImpl::eek:nConnCfmd: ConnCfmd: 103@L:2@C:e
    01:23:36.609|DialogUsageManager.cxx(1190)|Trace5|Resip|>>: Got: SipReq: ACK 1950222e1@88.217.42.212:5060 tid=a3d9d4ed4d033194ec2f4e4f698d57d5 cseq=ACK contact=0172xxxxxxx@217.10.67.4 / 102 from(wire)
    01:23:36.609|DialogUsageManager.cxx(1516)|Trace5|Resip|>>: Handling in-dialog request: SipReq: ACK 1950222e1@88.217.42.212:5060 tid=a3d9d4ed4d033194ec2f4e4f698d57d5 cseq=ACK contact=0172xxxxxxx@217.10.67.4 / 102 from(wire)
    01:23:36.609|ServerInviteSession.cxx(684)|Trace5|Resip|>>: dispatchAccepted: SipReq: ACK 1950222e1@88.217.42.212:5060 tid=a3d9d4ed4d033194ec2f4e4f698d57d5 cseq=ACK contact=0172xxxxxxx@217.10.67.4 / 102 from(wire)
    01:23:36.609|InviteSession.cxx(2046)|Trace5|Resip|>>: Transition UAS_Accepted -> InviteSession::Connected
    01:23:36.609|.\ISHandler.cpp(82)|Trace5|CallControl|ISHandler::eek:nConnectedConfirmed: ConnCfmd: is=1180;rl=ACK sip:1950222e1@88.217.42.212:5060;rinstance=546e812a04581877 SIP/2.0
    01:23:36.609|.\Call.cpp(197)|Trace5|CallControl|CallLegImpl::eek:nConnCfmd: ConnCfmd: 10003@L:1@C:e
    01:23:39.828|TuSelector.cxx(70)|Trace5|Resip|>>: Stats message
    01:23:41.109|ServerAuthManager.cxx(363)|Trace5|Resip|>>: Sending challenge to SipReq: INVITE 0172xxxxxxx@10.0.1.100:5060 tid=-216854ea cseq=INVITE contact=103@10.0.1.50:5063 / 101 from(wire)
    01:23:41.109|ServerAuthManager.cxx(41)|Trace5|Resip|>>: ServerAuth challenged request SipReq: INVITE 0172xxxxxxx@10.0.1.100:5060 tid=-216854ea cseq=INVITE contact=103@10.0.1.50:5063 / 101 from(wire)
    01:23:41.234|ServerAuthManager.cxx(307)|Trace5|Resip|>>: Requesting credential for 103 @ 3CXPhoneSystem
    01:23:41.234|Helper.cxx(865)|Trace5|Resip|>>: username=103 password=9470 realm=3CXPhoneSystem method=INVITE uri=sip:0172xxxxxxx@10.0.1.100:5060 nonce=12821325821:b518875c1d152ab0b4d4164d486c3783
    01:23:41.234|ServerAuthManager.cxx(47)|Trace5|Resip|>>: ServerAuth requested credentials SipReq: INVITE 0172xxxxxxx@10.0.1.100:5060 tid=-3b62688e cseq=INVITE contact=103@10.0.1.50:5063 / 102 from(wire)
    01:23:41.234|ServerAuthManager.cxx(125)|Trace5|Resip|>>: Checking for auth result in realm=3CXPhoneSystem A1=
    01:23:41.234|ServerAuthManager.cxx(210)|Trace5|Resip|>>: Authorized request for 3CXPhoneSystem
    01:23:41.234|.\Authorization.cpp(241)|Trace5|Authorization|AuthMgr::eek:nAuthSuccess: Caller "103"<sip:103@10.0.1.50:5063>;tag=63cd0874c0b57c66i3 has been authenticated successfully
    01:23:41.234|DialogUsageManager.cxx(1190)|Trace5|Resip|>>: Got: SipReq: INVITE 0172xxxxxxx@10.0.1.100:5060 tid=-3b62688e cseq=INVITE contact=103@10.0.1.50:5063 / 102 from(wire)
    01:23:41.234|DialogUsageManager.cxx(1516)|Trace5|Resip|>>: Handling in-dialog request: SipReq: INVITE 0172xxxxxxx@10.0.1.100:5060 tid=-3b62688e cseq=INVITE contact=103@10.0.1.50:5063 / 102 from(wire)
    01:23:41.234|InviteSession.cxx(2046)|Trace5|Resip|>>: Transition InviteSession::Connected -> InviteSession::ReceivedReinvite
    01:23:41.234|.\ISHandler.cpp(157)|Trace5|CallControl|ISHandler::eek:nOffer: Offered: is=1183; rl=INVITE sip:0172xxxxxxx@10.0.1.100:5060 SIP/2.0
    01:23:41.234|.\CallStrategies.cpp(122)|Trace5|CallManager|StratLink::eek:nOffer: Link: Offer from 103@L:2@C:e
    01:23:41.234|.\CallStrategies.cpp(141)|Trace5|CallManager|StratLink::eek:nOffer: Link: Got HoldRequest from 103@L:2@C:e for 10003@L:1@C:e
    01:23:41.234|.\Call.cpp(904)|Trace5|CallControl|CallLegImpl::provideOffer: Provide offer to Ln:10003@sipgate_geheim
    01:23:41.234|ServerInviteSession.cxx(154)|Trace5|Resip|>>: InviteSession::Connected: provideOffer
    01:23:41.234|InviteSession.cxx(2046)|Trace5|Resip|>>: Transition InviteSession::Connected -> InviteSession::SentReinvite
    01:23:41.234|InviteSession.cxx(334)|Trace5|Resip|>>: Sending SipReq: INVITE 0172xxxxxxx@217.10.67.4 tid=e7562b7aff462709 cseq=INVITE contact=1950222e1@10.0.1.100:5060 / 2 from(tu)
    01:23:41.234|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend: InviteSession(1180) sends INVITE sip:0172xxxxxxx@217.10.67.4 SIP/2.0
    01:23:41.234|.\Call.cpp(943)|Trace5|CallControl|CallLegImpl::provideAnswer: Provide answer (MS) to 103@L:2@C:e
    01:23:41.234|ClientInviteSession.cxx(118)|Trace5|Resip|>>: InviteSession::ReceivedReinvite: provideAnswer
    01:23:41.234|InviteSession.cxx(2046)|Trace5|Resip|>>: Transition InviteSession::ReceivedReinvite -> InviteSession::Connected
    01:23:41.234|InviteSession.cxx(391)|Trace5|Resip|>>: Sending SipResp: 200 tid=-3b62688e cseq=INVITE contact=0172xxxxxxx@10.0.1.100:5060 / 102 from(tu)
    01:23:41.234|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend: InviteSession(1183) sends SIP/2.0 200 OK
    01:23:41.234|.\CallEvents.cpp(78)|Trace5||FireStatusEvent: Fire event: OnHold; DN 103
    01:23:41.343|DialogUsageManager.cxx(1190)|Trace5|Resip|>>: Got: SipReq: ACK 0172xxxxxxx@10.0.1.100:5060 tid=-fe8d0dff cseq=ACK contact=103@10.0.1.50:5063 / 102 from(wire)
    01:23:41.343|DialogUsageManager.cxx(1516)|Trace5|Resip|>>: Handling in-dialog request: SipReq: ACK 0172xxxxxxx@10.0.1.100:5060 tid=-fe8d0dff cseq=ACK contact=103@10.0.1.50:5063 / 102 from(wire)
    01:23:41.406|DialogUsageManager.cxx(1190)|Trace5|Resip|>>: Got: SipResp: 100 tid=773ddf45b45cbc61 cseq=INVITE / 2 from(wire)
    01:23:41.421|DialogUsageManager.cxx(1190)|Trace5|Resip|>>: Got: SipResp: 200 tid=773ddf45b45cbc61 cseq=INVITE contact=0172xxxxxxx@217.10.67.4 / 2 from(wire)
    01:23:41.421|InviteSession.cxx(2046)|Trace5|Resip|>>: Transition InviteSession::SentReinvite -> InviteSession::Connected
    01:23:41.421|InviteSession.cxx(2343)|Trace5|Resip|>>: Sending SipReq: ACK 0172xxxxxxx@217.10.67.4 tid=b269a659d47b9373 cseq=ACK contact=1950222e1@10.0.1.100:5060 / 2 from(tu)
    01:23:41.421|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend: InviteSession(1180) sends ACK sip:0172xxxxxxx@217.10.67.4 SIP/2.0
    01:23:41.421|.\ISHandler.cpp(149)|Trace5|CallControl|ISHandler::eek:nAnswer: Answered: is=1180; rl=SIP/2.0 200 OK
    01:23:41.421|.\CallStrategies.cpp(208)|Trace5|CallManager|StratLink::eek:nAnswer: Link: got answer from 10003@L:1@C:e
    01:23:41.421|.\CallStrategies.cpp(224)|Trace5|CallManager|StratLink::eek:nAnswer: Link: On-Hold is confirmed from 10003@L:1@C:e
    01:23:41.421|.\CallEvents.cpp(78)|Trace5||FireStatusEvent: Fire event: Held; DN 10003
    01:23:50.234|ServerAuthManager.cxx(307)|Trace5|Resip|>>: Requesting credential for 103 @ 3CXPhoneSystem
    01:23:50.234|Helper.cxx(865)|Trace5|Resip|>>: username=103 password=9470 realm=3CXPhoneSystem method=INVITE uri=sip:0172xxxxxxx@10.0.1.100:5060 nonce=12821325821:b518875c1d152ab0b4d4164d486c3783
    01:23:50.234|ServerAuthManager.cxx(47)|Trace5|Resip|>>: ServerAuth requested credentials SipReq: INVITE 0172xxxxxxx@10.0.1.100:5060 tid=-bd18c2ba cseq=INVITE contact=103@10.0.1.50:5063 / 103 from(wire)
    01:23:50.234|ServerAuthManager.cxx(125)|Trace5|Resip|>>: Checking for auth result in realm=3CXPhoneSystem A1=
    01:23:50.234|ServerAuthManager.cxx(210)|Trace5|Resip|>>: Authorized request for 3CXPhoneSystem
    01:23:50.234|.\Authorization.cpp(241)|Trace5|Authorization|AuthMgr::eek:nAuthSuccess: Caller "103"<sip:103@10.0.1.50:5063>;tag=63cd0874c0b57c66i3 has been authenticated successfully
    01:23:50.234|DialogUsageManager.cxx(1190)|Trace5|Resip|>>: Got: SipReq: INVITE 0172xxxxxxx@10.0.1.100:5060 tid=-bd18c2ba cseq=INVITE contact=103@10.0.1.50:5063 / 103 from(wire)
    01:23:50.234|DialogUsageManager.cxx(1516)|Trace5|Resip|>>: Handling in-dialog request: SipReq: INVITE 0172xxxxxxx@10.0.1.100:5060 tid=-bd18c2ba cseq=INVITE contact=103@10.0.1.50:5063 / 103 from(wire)
    01:23:50.234|InviteSession.cxx(2046)|Trace5|Resip|>>: Transition InviteSession::Connected -> InviteSession::ReceivedReinvite
    01:23:50.234|.\ISHandler.cpp(157)|Trace5|CallControl|ISHandler::eek:nOffer: Offered: is=1183; rl=INVITE sip:0172xxxxxxx@10.0.1.100:5060 SIP/2.0
    01:23:50.234|.\CallStrategies.cpp(122)|Trace5|CallManager|StratLink::eek:nOffer: Link: Offer from 103@L:2@C:e
    01:23:50.234|.\CallStrategies.cpp(154)|Trace5|CallManager|StratLink::eek:nOffer: Link: Got 'Retrieve' for 10003@L:1@C:e from 103@L:2@C:e
    01:23:50.234|.\CallEvents.cpp(78)|Trace5||FireStatusEvent: Fire event: Connected; DN 103
    01:23:50.234|.\CallStrategies.cpp(157)|Trace5|CallManager|StratLink::eek:nOffer: Both legs are local, switch to direct media connection
    01:23:50.234|.\Call.cpp(904)|Trace5|CallControl|CallLegImpl::provideOffer: Provide offer to Ln:10003@sipgate_geheim
    01:23:50.234|ServerInviteSession.cxx(154)|Trace5|Resip|>>: InviteSession::Connected: provideOffer
    01:23:50.234|InviteSession.cxx(2046)|Trace5|Resip|>>: Transition InviteSession::Connected -> InviteSession::SentReinvite
    01:23:50.234|InviteSession.cxx(334)|Trace5|Resip|>>: Sending SipReq: INVITE 0172xxxxxxx@217.10.67.4 tid=2d04963536307f0a cseq=INVITE contact=1950222e1@10.0.1.100:5060 / 3 from(tu)
    01:23:50.234|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend: InviteSession(1180) sends INVITE sip:0172xxxxxxx@217.10.67.4 SIP/2.0
    01:23:50.375|DialogUsageManager.cxx(1190)|Trace5|Resip|>>: Got: SipResp: 100 tid=080b3f289419b22e cseq=INVITE / 3 from(wire)
    01:23:50.406|DialogUsageManager.cxx(1190)|Trace5|Resip|>>: Got: SipResp: 200 tid=080b3f289419b22e cseq=INVITE contact=0172xxxxxxx@217.10.67.4 / 3 from(wire)
    01:23:50.406|InviteSession.cxx(2046)|Trace5|Resip|>>: Transition InviteSession::SentReinvite -> InviteSession::Connected
    01:23:50.406|InviteSession.cxx(2343)|Trace5|Resip|>>: Sending SipReq: ACK 0172xxxxxxx@217.10.67.4 tid=7151806932073036 cseq=ACK contact=1950222e1@10.0.1.100:5060 / 3 from(tu)
    01:23:50.406|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend: InviteSession(1180) sends ACK sip:0172xxxxxxx@217.10.67.4 SIP/2.0
    01:23:50.406|.\ISHandler.cpp(149)|Trace5|CallControl|ISHandler::eek:nAnswer: Answered: is=1180; rl=SIP/2.0 200 OK
    01:23:50.406|.\CallStrategies.cpp(208)|Trace5|CallManager|StratLink::eek:nAnswer: Link: got answer from 10003@L:1@C:e
    01:23:50.406|.\CallStrategies.cpp(232)|Trace5|CallManager|StratLink::eek:nAnswer: Link: Retrieve from hold is confirmed from 10003@L:1@C:e
    01:23:50.406|.\CallEvents.cpp(78)|Trace5||FireStatusEvent: Fire event: Connected; DN 10003
    01:23:50.406|.\Call.cpp(947)|Trace5|CallControl|CallLegImpl::provideAnswer: Provide answer (direct) to 103@L:2@C:e
    01:23:50.406|ClientInviteSession.cxx(118)|Trace5|Resip|>>: InviteSession::ReceivedReinvite: provideAnswer
    01:23:50.406|InviteSession.cxx(2046)|Trace5|Resip|>>: Transition InviteSession::ReceivedReinvite -> InviteSession::Connected
    01:23:50.406|InviteSession.cxx(391)|Trace5|Resip|>>: Sending SipResp: 200 tid=-bd18c2ba cseq=INVITE contact=0172xxxxxxx@10.0.1.100:5060 / 103 from(tu)
    01:23:50.406|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend: InviteSession(1183) sends SIP/2.0 200 OK
    01:23:50.515|DialogUsageManager.cxx(1190)|Trace5|Resip|>>: Got: SipReq: ACK 0172xxxxxxx@10.0.1.100:5060 tid=-6d389d59 cseq=ACK contact=103@10.0.1.50:5063 / 103 from(wire)
    01:23:50.515|DialogUsageManager.cxx(1516)|Trace5|Resip|>>: Handling in-dialog request: SipReq: ACK 0172xxxxxxx@10.0.1.100:5060 tid=-6d389d59 cseq=ACK contact=103@10.0.1.50:5063 / 103 from(wire)
    01:23:53.671|TransactionState.cxx(470)|Trace5|Resip|>>: discarding stray response: SipResp: 180 tid=cd2aa261aa4d1c48 cseq=INVITE contact=300@10.0.1.53:5060 / 1 from(wire)
    01:23:54.343|DialogUsageManager.cxx(1190)|Trace5|Resip|>>: Got: SipReq: BYE 1950222e1@88.217.42.212:5060 tid=fb78.102ae75.0 cseq=BYE / 103 from(wire)
    01:23:54.343|DialogUsageManager.cxx(1516)|Trace5|Resip|>>: Handling in-dialog request: SipReq: BYE 1950222e1@88.217.42.212:5060 tid=fb78.102ae75.0 cseq=BYE / 103 from(wire)
    01:23:54.343|InviteSession.cxx(1592)|Trace5|Resip|>>: Received SipReq: BYE 1950222e1@88.217.42.212:5060 tid=fb78.102ae75.0 cseq=BYE / 103 from(wire)
    01:23:54.343|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend: InviteSession(1180) sends SIP/2.0 200 OK
    01:23:54.343|InviteSession.cxx(2046)|Trace5|Resip|>>: Transition InviteSession::Connected -> InviteSession::Terminated
    01:23:54.343|.\ISHandler.cpp(100)|Trace5|CallControl|ISHandler::eek:nTerminated: Terminated: is=1180;reason=PeerEnded;rl=BYE sip:1950222e1@88.217.42.212:5060;rinstance=546e812a04581877 SIP/2.0
    01:23:54.343|.\CallStrategies.cpp(262)|Log2|CallManager|StratLink::eek:nHangUp: Call(C:E): got Hang-Up from Ln:10003@sipgate_geheim; reason: BYE
    01:23:54.343|.\CallConf.cpp(365)|Trace5|CallControl|CallConf::changeStrategy: Call C:E changes strategy CS.Link to <null>
    01:23:54.343|.\CallEvents.cpp(78)|Trace5||FireStatusEvent: Fire event: OnHook; DN 103
    01:23:54.343|ClientInviteSession.cxx(174)|Trace5|Resip|>>: InviteSession::Connected: end
    01:23:54.343|InviteSession.cxx(2360)|Trace5|Resip|>>: "0172xxxxxxx"<sip:0172xxxxxxx@sipgate.de>;tag=e5067445 Sending BYE
    01:23:54.343|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend: InviteSession(1183) sends BYE sip:103@10.0.1.50:5063 SIP/2.0
    01:23:54.343|.\ISHandler.cpp(101)|Trace5|CallControl|ISHandler::eek:nTerminated: Terminated: is=1183;reason=Ended
    01:23:54.343|.\Call.cpp(223)|Trace5|CallControl|CallLegImpl::eek:nEnded: Leg.onEnded 103@L:2@C:e got zero msg
    01:23:54.343|.\CallConf.cpp(412)|Trace5|CallControl|CallConf::~CallConf: Destroying call C:E
    01:23:54.343|.\CallEvents.cpp(78)|Trace5||FireStatusEvent: Fire event: OnHook; DN 10003
    01:23:54.343|.\Call.cpp(1138)|Trace5|CallControl|CallLegImpl::~CallLegImpl: Leg 103@L:2@C:e is destroyed
    01:23:54.406|.\Call.cpp(1138)|Trace5|CallControl|CallLegImpl::~CallLegImpl: Leg 10003@L:1@C:e is destroyed
    01:23:54.453|DialogUsageManager.cxx(1190)|Trace5|Resip|>>: Got: SipResp: 200 tid=cb24990a827ab076 cseq=BYE / 2 from(wire)
    01:23:54.453|InviteSession.cxx(1466)|Trace5|Resip|>>: InviteSession::dispatchTerminated SipResp: 200 tid=cb24990a827ab076 cseq=BYE / 2 from(wire)
    Hope this will help to find the error, why since Version RC2 no MOH is played .... on RC1 it worked.
    Greethings,
    Michael.
