Music On Hold
Discussion in '3CX Phone System - General' started by fripsy, Jun 18, 2007.
  1. fripsy
    Jun 18, 2007
    Hi All,
    I'm currently struggling with the music on hold feature.
    With an outbound call, it is working fine, however with an inbound call I get the following message in the server log:
    from 'server:0/MediaServer':EP 0000005C@(ACTIVE): Can't send RTP stream to 0.0.0.0:13796 destination unreachable
    The weird thing is that with an outbound call I get the same error from the Mediaserver, but the music is playing.
    I'm using v3.0.1928.0
    Any ideas?
    Frank
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    I suspect some party doesn't support re-INVITE. You may bind it to Media Server, and it will work always.
  3. fripsy
    Jun 18, 2007
    Hi Archie,
    Thanks for the quick reply.
    Just verified the settings, re-invite is checked and bind to mediaserver is also checked, but no go.
    Internal calls on hold don't get the music either, but I guess that's normal.
    meanwhile I've tried every combination external/mediaserver on every line, but no luck. It works perfectly on outbound calls though.
    Frank
  4. archie
    3CX Support
    Aug 18, 2006
    1,299
    What is your hardware?
    Try to uncheck 'Supports re-invite'
  5. fripsy
    Jun 18, 2007
    Great Archie!
    Unchecking re-invite did the trick, the one thing I didn't tried.... :wink:
    BTW, it was on a GIZMO VoIP line.
    Everything is working like a charm now!
    Thanks a lot!
    Frank.
