Music on ring
Discussion in '3CX Phone System - General' started by KOUSIS, Nov 30, 2010.
  1. KOUSIS
    Nov 17, 2010
    26
    Hello
    I want when someone calls to hear a music song or a audio message and then to hear the ring tone.
    How can i do this?
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    HI,
    So if someone calls in you want them to hear music on hold and then riniging. You would need to use a DR which ahs both the audio file and ringing tone recorded in one file to mimick what you want set the DR to go to the phone you desire once it has played the audio file.
  3. KOUSIS
    Nov 17, 2010
    26
    What is the DR?
  4. aveiser@veiser.de
    Dec 23, 2008
    23
    Digital Receptionist
  5. mfm
    mfm Active Member
    Mar 4, 2010
    641
    If you are a new user to 3CX i suggest you read the manual before diving into such a system.
    http: //www.3cx.com/manual/3CXPhoneSystemManual9.pdf NO LONGER AVAILABLE. NEW LINK: http://www.3cx.com/docs/manual/
    It will greatly help you achieve your goals and achieve goals you never realised you could. Best of luck!
  6. KOUSIS
    Nov 17, 2010
    26
    I've created a wav file and i created the DR but it keep ringing and no sound
    Do i have to do something else?
  7. mfm
    mfm Active Member
    Mar 4, 2010
    641
    If you have forwarded you call to Digital receptionist, and the call is reaching the PBX you should not hear ringing. Can you provide the logs and please use code and /code tags.
  8. KOUSIS
    Nov 17, 2010
    26
    thank you for your reply, i manage to do what i want, it was my mistake
  9. mfm
    mfm Active Member
    Mar 4, 2010
    641
    No problem, were always happy to help.
