Music Onhold Drops when Queue transfers to External
Discussion in '3CX Phone System - General' started by radcomp, Aug 20, 2010.
  1. radcomp
    Aug 21, 2008
    35
    Hi Just wondering if any has a solution to my problem.
    An External call Comes in and spends 60 seconds in a queue (this is all fine) but when noone picks up and the call is transfered to an external number the onhold audio cuts out and there is silence until 10 seconds later the external person answers there phone then the audio works.
    Thanks and please help.
    josh
  2. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    19
    Yes , we know about this, and we will provide a fix for this.
    It only happens when the call is forwarded to an Outside Number. We will let you know about this later on.
    Thanks and Regards
