Music while call is transfered
Discussion in '3CX Phone System - General' started by opera01, May 24, 2009.
  1. opera01
    Apr 2, 2009
    25
    Why doesnt the caller get music while they are being transfered to a ring group? Or, how is it possible to get music while they are waiting for someone to pic up the phone??
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    the caller get a music while hold or transfer
  3. opera01
    Apr 2, 2009
    25
    it doesnt work for me. May be because i transfer to an external number. But if noone answer the phone the caller is routed back to the pbx... Is there a possibility to get music on hold while transfering to external number?
    (i have set up extentions to forward directly to an external number, and included theese extentions in a ring group)
  4. mbaltus
    Dec 12, 2008
    66
    It should work out of the box. Are you running Windows 2008 as server for 3CX, because then you may have to install the Desktop Experience feature before MP3 files are correctly played.
  5. opera01
    Apr 2, 2009
    25
    im using windows 2003 as a server for 3cx. Do i need to install Desktop Experience feature to get it work? Where do i find it?
    Is another option to make a music-on-hold.wav? (that is not the best option thou, because of all the other mp3 prompt, that may not work)
  6. mbaltus
    Dec 12, 2008
    66
    No, desktop experience is a Windows 2008 feature. Windows 2003 should support it by default. You can try to see if it works with a WAV file. You can change the file that's used as MOH from the 3CX settings.
  7. opera01
    Apr 2, 2009
    25
    It still doesnt work. Ive changed the format from mp3 to wav.... (with audacity)
    It is totaly silence after "Please hold, while I transfer your call", but the forwarding is working fine and the external phone is ringing..
    Everything except that is working perfectly!
    I have also tried to transfer only to local phone, but still no music on hold. Even if I answer the phone, and put the caller on hold, music on hold still doesnt work.
    I cant see why music on hold will not work...?
  8. mbaltus
    Dec 12, 2008
    66
    And you have checked that in the options the correct file is shown?
    When you play the file from your PC, it is audible?
    Can you try to set the log to Verbose (restart the services) and see if anything pops-up in the logs?
  9. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Logs... 3cxmediaserver.trace.log or 3cxmediaserver.log...
    http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html :)
  10. opera01
    Apr 2, 2009
    25
    Everything seems fine.
    Cant find any failure message, except this:
    20:42:50.796 Unknown system [DBProvider] tries to connect!
    20:42:50.796 SL: connected BAB-02:5485/DBProvider at [BAB-02:5485]/DBProvider
    20:42:50.781 [CM501010]: License Info: Load Failed
  11. SY
    3CX Support
    Jan 26, 2007
    1,825
    Is it quotation from the "..3cxmediaserver.trace.log or 3cxmediaserver.log..."?
  12. mbaltus
    Dec 12, 2008
    66
    Although MOH is not restricted to the paid versions of 3CX, I suggest that you try to fix these errors first. Naturally I assume that you are currently running the latest build of 3CX (that has helped me several times already as well). Do you have a paid version of 3CX? than you may need to reregister the license code.
  13. opera01
    Apr 2, 2009
    25
    3cxmediaserver.trace.log (with changed/"masked" ip adresses):
    2009/05/25 >>
    20:42:53.046|.\Service.cpp(244)|Log2||??:*** Initialize ***
    20:42:53.046|.\Service.cpp(320)|Log2||??:*** Start Server ***
    20:42:53.234|.\Service.cpp(80)|Log2||??:*** Listen ***
    20:42:53.234|.\Service.cpp(96)|Log2||??:*** Connecting to [127.0.0.1:5482] ***
    20:42:53.234|.\Service.cpp(107)|Log2||??:*** Connected to BAB-02:5482/CallManager at 127.0.0.1:5482 ***
    20:42:59.921|.\Service.cpp(159)|Trace5||??:parametersUpdated:=====[00986F00]
    STUN=ARRAY
    [0]=stun.3cx.com:3478
    [1]=stun2.3cx.com:3478
    ADD2833=1
    ANSP=0
    CS=62914560
    EXTADDR=80.100.100.10
    EXTIF=10.10.10.4
    FEP=9000
    FLP=7000
    LEP=9049
    LLP=7499
    LOCALADDR=
    MCFS=5242880
    MOH=C:\Documents and Settings\All Users\Application Data\3CX\Data\Ivr\Prompts\onhold2.wav
    MS_BLINDEXTPORTS=0
    STUNTOUT=3000
    TOS=0
    allowExternalOn=0.0.0.0/0
    allowSourceAsOutbound=0
    externalIPRange=
    reportSourceConflicts=0
    3cxmediaserver.log whas empty
  14. SY
    3CX Support
    Jan 26, 2007
    1,825
    Hmm... Where is the call?
  15. opera01
    Apr 2, 2009
    25
    and here is the log in verbosity mode. Have changed local / external ip to "ip dummy adresses".
  16. SY
    3CX Support
    Jan 26, 2007
    1,825
    ...and... where is a call?
    P.S. It looks like we are going through the circle, isn't it?
  17. opera01
    Apr 2, 2009
    25
    Sorry! Didnt se the message before i answered.
    I cleared the log, and forgot to try to call.
    Here is it with a call... (I didnt pick up the phone...)
  18. opera01
    Apr 2, 2009
    25
    and here is the verbosity log.
    (I did call 2 times. First i forgot to turn on 3cx client on computer, second time i called, i had turned on the client and it was ringing, but i didt pick up the phone.)
  19. SY
    3CX Support
    Jan 26, 2007
    1,825
    RFC 3264: An Offer/Answer Model with the Session Description Protocol (SDP)
    If you are trying to debug "Sippy" then please open the support ticket and specify deviations of your software.
    If you need to make it works then:
    "Support reinvites" = off - it will work like a charm (hopefully :) )
    Regards
  20. opera01
    Apr 2, 2009
    25
    Thank you! It works fine with Support re-invites=off...
    Can u tell me what Support re-invites is, little more spesific?
