mute all other sound windows 7 doesnt work
Discussion in 'Windows' started by mmo12345, Jun 22, 2011.
  1. mmo12345
    Jun 22, 2011
    I'm using 3cxphone 6 on windows 7 x64 but when I 'm using the 3cx phone it doesn't mute all other sounds (like radio player).
    I configured the setting to do this in windows.
    when I'm using skype it works perfect.
    please help how to fix
    thanks
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,502
    69
    At this moment, 3CXPhone don't use OS version-specific APIs, but only common ones - starting with XP. So, the feature you want is not available. We will check for this in future releases.
    Regards
    vali
  3. mmo12345
    Jun 22, 2011
    thanks for mentioning, I was almost sure it was posible but unfortunualy :(
    this is realy a needed feature
    thanks
