Mute beeping voicemail notification on Polycom phones
Discussion in '3CX Phone System - General' started by double8pex, Sep 23, 2010.
  1. double8pex
    Jun 8, 2010
    13
    Is there a way to mute or silence the beeping/blurping noise the Polycom phones make when someone leaves a voicemail?
    Yes, we'd like to keep the message indicator light blinking, but we don't need to hear the message waiting beeps (which does it like every couple of minutes or so).
    We are using Polycom 331, 450, and 650 phones with 3CX version 8.
  2. techvana
    Sep 22, 2010
    15
    I'm wondering this too. Thanks.
