MWI Indicator or tone?
Discussion in '3CX Phone System - General' started by rstille, Feb 6, 2010.
  1. rstille
    Jan 30, 2010
    10
    All, I have an older set of Polycom IP500 phones that I have been able to provision fairly successfully thus far with 3cX. Voicemail, generally, is working fine, excepting that there is no message waiting indicator on the phone, or tone that is presented when the handset is lifted, when a voicemail is received. Also, when you select the 'messages' button on the keypad, it does not indicate that there are any messages waiting.
    Is there a way to do this?
    I am using the free/evaluation version of 3cX currently.
    Thanks,
    Randy
  2. rstille
    Jan 30, 2010
    10
    Thanks Matt .. what commercial version is it supported in?
    Is there a way to at least get a warble tone or something on handset pickup to tell someone a message has been received?
    Thanks,
    Randy
  3. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Any of the paid versions support MWI, the "free" version is not really intended for production systems with key features like MWI missing.
  4. pjr
    pjr New Member
    Oct 5, 2009
    154
    If you gave legit details when you downloaded 3CX, you should have been emailed a code for a 2 consecutive call "paid" licence.
    This key enables all the features of the paid version (inc MWI) but only allows 2 consecutive calls.
    Paul
  5. nb
    nb Support Team
    Jun 7, 2007
    2,128
    152
    Yes with the demo key, you will get full features enabled for evaluation.
  6. rstille
    Jan 30, 2010
    10
    Thanks guys, for the help!
    In the free edition, I believe I have 4 simultaneous lines, correct? So the choice is 2 simultaneous lines w/ MWI, or 4 simultaneous w/o MWI ...
    I do have the key, if I choose that direction ...
    Thanks,
    Randy
  7. nb
    nb Support Team
    Jun 7, 2007
    2,128
    152
    You have 4 sim calls
    However you have no features. So no MWI
    Now you have a demo key which will reduce the lines from 4 to 2 but will give you full features to evaluate them.
  8. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,475
    94
    In the Free Edition you get 4 Sim Calls.
    In the Evaluation Edition you get 2 Sim Calls but Full Features.
