MWI stopped working after upgrading to 15.5.15502.6
Discussion in '3CX Phone System - General' started by amohod, Jan 14, 2019.
  1. amohod
    Jun 26, 2014
    23
    The message light is not blinking when message are present in voicemail. This issue started after we upgraded to version 15.5.15502.6. We tested with multiple phones but same issue observed. We are having grandstream 1625 phones.
    When we tried to configured email alert for voicemail, it was also not working. Please advice how to resolve both the issues.
    Regards
    Avinash
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,327
    221
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    564
    Also do other emails from the system work correctly? What SMTP server are you using? If you dial the voicemail of the extension is the voicemail present and can be heard?
  4. amohod
    Jun 26, 2014
    23
  5. amohod
    Jun 26, 2014
    23
    Email notification works for system alerts. Only vociemail alerts are not working
  6. YiannisH_3CX
    May 10, 2016
    7,783
    564
  7. amohod
    Jun 26, 2014
    23
    Yes when we dial into voicemail, there is voicemail is present. Even when did test call by recording new vociemail the lamp does not come up.
  8. YiannisH_3CX
    May 10, 2016
    7,783
    564
    Can you install a 3CX client on the same extension and tell me if you see the notification there?
  9. amohod
    Jun 26, 2014
    23
    We tested with 3cx client and vociemail is not showing up there either. We recorded three test messages but 3cx softphone is showing none.
  10. amohod
    Jun 26, 2014
    23
    Just want to inform you that MWI is not working all phones....looks like issue with 3cx
  11. YiannisH_3CX
    May 10, 2016
    7,783
    564
    In that case then i would recommend creating a ticket with our support department so they can look into the issue and determine what is causing it.
