My I phone still not registered , Can any one help me ?!
Discussion in 'iOS' started by Swalf, Jan 25, 2012.
  1. Swalf
    Jan 25, 2012
    Hello ,
    I already installed the 3CX 1.1.4 , and I use the same Configuration for the Andriod , but still my phone not registered.
    I can not select 3CX tunnel , whereas I read in the fourm the RTP it can be 9000-9049. But still also not working. Can any one guide me to solve the problem.
    Best Regards
    11,117
    329
    So...your Android phone does, or doesn't work?
    Are you trying this using 3G or WiFI. Try getting it working first on WiFi as 3G (on some networks) can introduce other problems.
    I'm assuming this is being used as a 3CX extension as you mention the tunnel option. Is there no sign of a registration attempt?
    You have allowed remote extensions to register in the 3CX extension options? Are your server settings "pointed" to an IP or domain name?
