Solved My maintenance is paid for, but can't download updates
Discussion in '3CX Phone System - General' started by David Tutwiler, Apr 6, 2017.
  1. David Tutwiler
    Jan 13, 2017
    12
    On the dashboard it shows my original expiration date (03/14/2017), but if I double click that field and look in the license settings, it shows my maintenance expires 03/14/2018 at 6:00:00 AM. This is really hindering me as I need to install updates but can't.
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Have you tried editting the licence and save (without actually editing anything)?
  3. David Tutwiler
    Jan 13, 2017
    12
    That easy, huh? I tried it and worked like a charm. Thanks.
  4. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Awesome.
