My microphone is disabled how can I trouble shoot
Discussion in '3CX Phone System - General' started by batata, Nov 14, 2007.
  1. batata
    Oct 24, 2007
    Hi I have installed 3cx phone
    I have a sound max digital audio card
    My mike is disabled even if I select the default ou the sond max the res cross shows. Any knows how to solve
    Thank you
    Batata
  2. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    You mean you an use it even on another windows application?
    Or just the 3CX Phone?
  3. batata
    Oct 24, 2007
    just 3x phone. I am able to record in windows recorder
    i call using 3cx pbx and inphonex
    thank you
