My Phone over Bridge
Discussion in '3CX Phone System - General' started by eclipse2000, Jul 10, 2012.
  1. eclipse2000
    Feb 3, 2011
    31
    I currently have a master server running 10 extensions and all sip connections, i also have a slave server connected over a bridge running another 10 externsions. When using MyPhone connected to an extension on the master server its only showing me the extensions local to that server and not over the bridge. Is there a way of doing this?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,560
    301
    1) In the bridge, select which extensions can see remote extensions... you can easily check 'select all'
    2) be sure to select the tab of the remote site (above the buttons) in MyPhone
    3) Ensure you are on Pro or Ent version to receive the information from a remote site.
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    Not certain, but I think you must be running v11 for this functionality and will need to update the MyPhone app as well.
