My Phone - Remember Me
Discussion in 'Windows' started by bluestar, Aug 4, 2011.
  1. bluestar
    Jan 6, 2011
    12
    There seems to be an issue with the "Rember me" function on MyPhone. It seems that it only rembers you for that session, if you restart the PC you need to provide your extension settings again.
    Is this by design or is this a bug. My users love the MyPhone interface v. the old Assistant, but the constant need for them to remeber yet another PIN/Pass is a point of issue.
    Can I suggest if this is by design that there be an option to permanently remember the details?
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    Hi, you need to check for the following:
    Start>Silverlight > Application Storage
    Enable application storage should be checked.
    If your problem still persist we will need to check.
    Please make sure that you are using the latest service pack.
  3. Ideasmiths
    Mar 23, 2008
    30
    This is quite interesting. I have been using Myphone and desktop component with Outlook 2010 for over 3 weeks, each time I had to log in again because I thought the remember me button is not working.
    After reading this post today. I launched the silverlight and although the settings were already there, after that 'peek', whenever I reboot, the remember features worked! :D But only if the laptop is not powered off (if only restart). If I shutdown, the next morning the remember me didn't work.
    Bug?
  4. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Have you updated to service pack 2? These problems went away for us after the update.
  5. Ideasmiths
    Mar 23, 2008
    30
    Yes, I have Service Pack 2.
  6. KerryG
    Jun 19, 2009
    960
    Clear your silverlight cache and clear your browser cache?
  7. Ideasmiths
    Mar 23, 2008
    30
    Interesting. I looked under control Panel ->Uninstall program and I found two 3CX Myphone, one is localhost and the second 192.168.100.26 which was my laptop static IP. So I uninstalled both and reboot.
    On the fresh boot, I launched a Firefox browser and this time on navigating to http://192.168.100.26:5000/myphone I entered the extension and Pin AND tick the remember me button. Previously I never tick the remember me button on the browser version because I knew I was going to install the desktop component immediately. I thought I will tick the remember me checkbox in the silverlight version of myphone.
    So this time after ticking the remember me in the browser version of myphone, installed the desktop component, checked that the control panel only shows 1 myphone (which is the static 192.168.100.26), checked silverlight has the storage space allocated as shown, I shutdown the laptop. Next day when I boot up the laptop the Myphone (silverlight) logged in automatically.
    [​IMG]
    I am running 3cx v 10 with SP2, 3cx phone v6, myphone (silverlight), win 7 x64.
