asinshesq
- Joined
- Apr 5, 2014
- Messages
- 73
- Reaction score
- 0
I have three yealink wired phones (two t20ps and one t46g) and two yealink w52p wireless phones on my lan (connected via 3cx of course), and I am using a patton 4112fxo to connect my voip phones to an outside pstn service. The wired phones work fine, but the wireless phones won't dial out. When I try to dial out with one of the wireless phones (using the outgoing rule that a prefix of 1 means to dial out), the phone appears to connect (the timer on the lcd starts and the phone does not time out), but I never hear the tone indicating the number I have dialed is ringing and no matter how long I wait the number never seems to actually get dialed).
In 3cx under options for the extension, I have confirmed that I did NOT disable external so that's not the issue.
I can also confirm that the wireless phones make calls to other extensions without a problem. And I can confirm that the wireless phones receive external and internal calls fine.
When I look at the log for a failed attempt to dial out via a wireless phone, it looks like it is working but in fact it is not. Here's the nonverbose log for a failed outgoing call:
And in case it's helpful, here's the verbose log for that call (though I'm not sure if it captures the entire thing in verbose mode):
26-Jul-2014 09:38:54.196 Leg L:4.2[Line:10000>>12125583000] is terminated: Cause: BYE from PBX
26-Jul-2014 09:38:54.195 [CM503008]: Call(C:4): Call is terminated
26-Jul-2014 09:38:54.191 Leg L:4.1[Extn] is terminated: Cause: BYE from 192.168.1.206:5062
26-Jul-2014 09:38:37.665 Currently active calls - 1: [4]
26-Jul-2014 09:38:23.010 [CM503007]: Call(C:4): Line:10000>>12125583000 has joined, contact <sip:[email protected]:5060>
26-Jul-2014 09:38:23.009 [CM503007]: Call(C:4): Extn:13 has joined, contact <sip:[email protected]:5062>
26-Jul-2014 09:38:23.003 L:4.2[Line:10000>>12125583000] has joined to L:4.1[Extn]
26-Jul-2014 09:38:23.003 [CM505002]: Gateway:[patton_4112fxo_gateway] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Patton SN4112 JO EUI 00A0BA0A1ED9 R6.5 2014-03-05 H323 SIP FXS FXO M5T SIP Stack/4.2.8.10] PBX contact: [sip:[email protected]:5060]
26-Jul-2014 09:38:17.742 [CM503025]: Call(C:4): Calling T:Line:10000>>12125583000@[Dev:sip:[email protected]:5060] for L:4.1[Extn]
26-Jul-2014 09:38:17.696 [CM503027]: Call(C:4): From: Extn:13 ("Great Rm" <sip:[email protected]:5060>) to T:Line:10000>>12125583000@[Dev:sip:[email protected]:5060]
26-Jul-2014 09:38:17.696 [CM503004]: Call(C:4): Route 1: from L:4.1[Extn] to T:Line:10000>>12125583000@[Dev:sip:[email protected]:5060]
26-Jul-2014 09:38:17.696 Line limit check: Current # of calls for line Lc:10000(@patton_4112fxo_gateway[<sip:[email protected]:5060>]) is 0; limit is 1
26-Jul-2014 09:38:17.696 Line limit check: Current # of calls for line Lc:10001(@patton_4112fxo_gateway[<sip:[email protected]:5062>]) is 0; limit is 1
26-Jul-2014 09:38:17.696 Call(C:4): Call from Extn:13 to 12125583000 matches outbound rule 'Rule for patton_4112fxo_gateway'
26-Jul-2014 09:38:17.694 [CM503001]: Call(C:4): Incoming call from Extn:13 to <sip:[email protected]:5060>
26-Jul-2014 09:38:54.196 L:4.2[Line:10000>>12125583000]: Terminating targets, reason:
26-Jul-2014 09:38:54.196 Terminated from <sip:[email protected]:5060>;tag=1726398550 to "Great Rm"<sip:[email protected]:5060>;tag=152b8e19; reason: LocalBye
26-Jul-2014 09:38:54.196 L:4.2[Line:10000>>12125583000] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=1e386b7b24294b33 Call-ID=ZjlhYjg3MWQ1MzUyNDJlOTEwYzYwYWY3ZjYxNGVkZDc.:
BYE sip:[email protected]:5060;transport=udp SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-1e386b7b24294b33-1---d8754z-;rport
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]:5060>;tag=1726398550
From: "Great Rm"<sip:[email protected]:5060>;tag=152b8e19
Call-ID: ZjlhYjg3MWQ1MzUyNDJlOTEwYzYwYWY3ZjYxNGVkZDc.
CSeq: 2 BYE
Content-Length: 0
26-Jul-2014 09:38:54.196 SendMsg from "Great Rm"<sip:[email protected]:5060>;tag=152b8e19 to <sip:[email protected]:5060>;tag=1726398550
26-Jul-2014 09:38:54.195 L:4.2[Line:10000>>12125583000]: Terminating targets, reason: SIP ;cause=200 ;text="Call terminated on user request"
26-Jul-2014 09:38:54.194 Blocking refers for the Call(C:4)
26-Jul-2014 09:38:54.194 Call(C:4) is terminated
26-Jul-2014 09:38:54.191 L:4.1[Extn]: Terminating targets, reason: SIP ;cause=200 ;text="User hangup"
26-Jul-2014 09:38:54.190 L:4.1[Extn] got Terminated Recv Req BYE from 192.168.1.206:5062 tid=1399855306 [email protected]:
BYE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.206:5062;branch=z9hG4bK1399855306
Max-Forwards: 70
Contact: <sip:[email protected]:5062>
To: <sip:[email protected]>;tag=9537e461
From: "Great Rm"<sip:[email protected]>;tag=1053633855
Call-ID: [email protected]
CSeq: 3 BYE
Proxy-Authorization: Digest username="13",realm="3CXPhoneSystem",nonce="414d535c09e4404908:3a56c0a212c19560ea2af71cd52ad395",uri="sip:[email protected]:5060",response="fe00428dfacdc10d4c2283eef7ba90d2",algorithm=MD5
User-Agent: Yealink SIP-W52P 25.50.0.20
Content-Length: 0
26-Jul-2014 09:38:54.190 Terminated from "Great Rm"<sip:[email protected]>;tag=1053633855 to <sip:[email protected]>;tag=9537e461; reason: RemoteBye
26-Jul-2014 09:38:54.190 L:4.1[Extn] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=1399855306 [email protected]:
SIP/2.0 200 OK
CSeq: 3 BYE
Content-Length: 0
26-Jul-2014 09:38:54.190 SendMsg from <sip:[email protected]>;tag=9537e461 to "Great Rm"<sip:[email protected]>;tag=1053633855
26-Jul-2014 09:38:23.125 Session 615 of leg L:4.1[Extn] is confirmed
26-Jul-2014 09:38:23.125 L:4.1[Extn] got Confirmed Recv Req ACK from 192.168.1.206:5062 tid=1311527999 [email protected]:
ACK sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.206:5062;branch=z9hG4bK1311527999
Max-Forwards: 70
CSeq: 2 ACK
Proxy-Authorization: Digest username="13", realm="3CXPhoneSystem", nonce="414d535c09e4404908:3a56c0a212c19560ea2af71cd52ad395", uri="sip:[email protected]", response="e6f5a8c5741eef9ccd45abbb068ab8f9", algorithm=MD5
Content-Length: 0
26-Jul-2014 09:38:23.125 ConnCfmd from "Great Rm"<sip:[email protected]>;tag=1053633855 to <sip:[email protected]>;tag=9537e461
26-Jul-2014 09:38:23.008 ~Target=PSTNline:12125583000@(Ln.10000@patton_4112fxo_gateway)
26-Jul-2014 09:38:23.008 Session 615 of leg L:4.1[Extn] is connected
26-Jul-2014 09:38:23.008 L:4.1[Extn] got Connected.UAS Send 200/INVITE from 0.0.0.0:0 tid=1519311582 [email protected]:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.206:5062;branch=z9hG4bK1519311582
CSeq: 2 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Content-Type: application/sdp
Supported: replaces
User-Agent: 3CXPhoneSystem 12.0.36097.670 (34969)
Content-Length: 226
v=0
o=3cxPS 340090945536 144300834817 IN IP4 192.168.1.201
s=3cxPS Audio call
c=IN IP4 192.168.1.202
t=0 0
m=audio 5122 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
26-Jul-2014 09:38:23.008 Connected(UAS) from "Great Rm"<sip:[email protected]>;tag=1053633855 to <sip:[email protected]>;tag=9537e461
26-Jul-2014 09:38:23.008 L:4.1[Extn] Sending: OnSendResp Send 200/INVITE from 0.0.0.0:0 tid=1519311582 [email protected]:
SIP/2.0 200 OK
CSeq: 2 INVITE
Supported: replaces
Content-Length: 226
v=0
s=3cxPS Audio call
t=0 0
a=fmtp:101 0-15
a=sendrecv
26-Jul-2014 09:38:23.008 SendMsg from <sip:[email protected]>;tag=9537e461 to "Great Rm"<sip:[email protected]>;tag=1053633855
26-Jul-2014 09:38:23.007 L:4.1[Extn]: Terminating targets, reason: SIP ;cause=200 ;text="Call completed elsewhere"
26-Jul-2014 09:38:23.003 ~Route=Dev:sip:[email protected]:5060
26-Jul-2014 09:38:23.003 Session 618 of leg L:4.2[Line:10000>>12125583000] is connected
26-Jul-2014 09:38:23.003 L:4.2[Line:10000>>12125583000] got Connected.UAC Recv 200/INVITE from 192.168.1.202:5060 tid=903a16235667f026 Call-ID=ZjlhYjg3MWQ1MzUyNDJlOTEwYzYwYWY3ZjYxNGVkZDc.:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.201:5060;branch=z9hG4bK-d8754z-903a16235667f026-1---d8754z-;rport=5060;received=192.168.1.201
Contact: <sip:[email protected]:5060;transport=udp>
CSeq: 1 INVITE
Server: Patton SN4112 JO EUI 00A0BA0A1ED9 R6.5 2014-03-05 H323 SIP FXS FXO M5T SIP Stack/4.2.8.10
Supported: replaces
Content-Length: 198
v=0
o=MxSIP 0 266 IN IP4 192.168.1.202
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=sendrecv
26-Jul-2014 09:38:23.003 Connected(UAC) from <sip:[email protected]:5060>;tag=1726398550 to "Great Rm"<sip:[email protected]:5060>;tag=152b8e19
26-Jul-2014 09:38:23.003 Remote SDP is set for leg L:4.2[Line:10000>>12125583000]
26-Jul-2014 09:38:23.003 Answer SDP arrived on Leg L:4.2[Line:10000>>12125583000];
OnAnswer Recv 200/INVITE from 192.168.1.202:5060 tid=903a16235667f026 Call-ID=ZjlhYjg3MWQ1MzUyNDJlOTEwYzYwYWY3ZjYxNGVkZDc.:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Content-Length: 198
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=sendrecv
26-Jul-2014 09:38:23.003 [CM503002]: Call(C:4): Alerting Line:10000>>12125583000 by contact <sip:[email protected]:5060>
26-Jul-2014 09:38:23.001 Phonebook entry not found for number 12125583000
26-Jul-2014 09:38:23.001 Looking for phone number 12125583000 in tenant's 'default' phonebook
26-Jul-2014 09:38:23.001 UacSession 618 has formed leg L:4.2[Line:10000>>12125583000]
26-Jul-2014 09:38:23.001 Answer from <sip:[email protected]:5060>;tag=1726398550 to "Great Rm"<sip:[email protected]:5060>;tag=152b8e19
26-Jul-2014 09:38:23.001 L:4.2[Line:10000>>12125583000] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=f64ac77b3264924f Call-ID=ZjlhYjg3MWQ1MzUyNDJlOTEwYzYwYWY3ZjYxNGVkZDc.:
ACK sip:[email protected]:5060;transport=udp SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-f64ac77b3264924f-1---d8754z-;rport
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
26-Jul-2014 09:38:23.001 SendMsg from "Great Rm"<sip:[email protected]:5060>;tag=152b8e19 to <sip:[email protected]:5060>;tag=1726398550
26-Jul-2014 09:38:17.742 Route to L:4.2[Line:10000>>12125583000] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=71105645b45e2f6a Call-ID=ZjlhYjg3MWQ1MzUyNDJlOTEwYzYwYWY3ZjYxNGVkZDc.:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-71105645b45e2f6a-1---d8754z-;rport
Max-Forwards: 70
CSeq: 1 INVITE
Supported: replaces
Content-Length: 238
v=0
o=3cxPS 19428016128 486824476673 IN IP4 192.168.1.201
s=3cxPS Audio call
c=IN IP4 192.168.1.206
t=0 0
m=audio 11794 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
26-Jul-2014 09:38:17.735 Outbound URI is used: sip:[email protected]:5060
26-Jul-2014 09:38:17.735 SLA is globally disabled
26-Jul-2014 09:38:17.733 Added leg L:4.2[Line:10000>>12125583000]
26-Jul-2014 09:38:17.696 [Flow] Call(C:4): making call from L:4.1[Extn] to T:Line:10000>>12125583000@[Dev:sip:[email protected]:5060]
26-Jul-2014 09:38:17.696 Line is not outbound: Lc:10001(@patton_4112fxo_gateway[<sip:[email protected]:5062>])
26-Jul-2014 09:38:17.696 [Flow] Call(C:4): has built target endpoint: Out#:>>Rule{Rule for patton_4112fxo_gateway}>>12125583000 for call from L:4.1[Extn]
26-Jul-2014 09:38:17.696 [Flow] Target endpoint for 12125583000 is Out#:>>Rule{Rule for patton_4112fxo_gateway}>>12125583000
26-Jul-2014 09:38:17.696 Looking for outbound rule: dialed = [12125583000], processed: [12125583000]; from-ext:
26-Jul-2014 09:38:17.696 [Flow] Building target endpoint to 12125583000 from "Great Rm" <sip:[email protected]:5060>
26-Jul-2014 09:38:17.696 [CM503010]: Call(C:4): Making route(s) from Extn:13 to <sip:[email protected]:5060>
26-Jul-2014 09:38:17.696 Remote SDP is set for leg L:4.1[Extn]
26-Jul-2014 09:38:17.696 OnOffer from "Great Rm"<sip:[email protected]>;tag=1053633855
26-Jul-2014 09:38:17.696 [CM505001]: Endpoint Extn:13: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Yealink SIP-W52P 25.50.0.20] PBX contact: [sip:[email protected]:5060]
26-Jul-2014 09:38:17.694 Inbound DID: ''; Phonebook Name: ''
26-Jul-2014 09:38:17.694 [CM500002]: Call(C:4): Info on incoming INVITE from Extn:13:
Invite-IN Recv Req INVITE from 192.168.1.206:5062 tid=1519311582 [email protected]:
INVITE sip:[email protected] SIP/2.0
Max-Forwards: 70
CSeq: 2 INVITE
Allow: INVITE, INFO, PRACK, ACK, BYE, CANCEL, OPTIONS, NOTIFY, REGISTER, SUBSCRIBE, REFER, PUBLISH, UPDATE, MESSAGE
Proxy-Authorization: Digest username="13",realm="3CXPhoneSystem",nonce="414d535c09e4404908:3a56c0a212c19560ea2af71cd52ad395",uri="sip:[email protected]",response="e6f5a8c5741eef9ccd45abbb068ab8f9",algorithm=MD5
Supported: replaces
Allow-Events: conference, refer, check-sync
Content-Length: 213
v=0
o=- 20010 20010 IN IP4 192.168.1.206
s=SDP data
t=0 0
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
26-Jul-2014 09:38:17.683 Outbound URI is used: sip:[email protected]:5062
26-Jul-2014 09:38:17.683 IncomingCall: C:4 from <sip:[email protected]:5060> to <sip:[email protected]:5060>
26-Jul-2014 09:38:17.683 Added leg L:C:4.1[No endpoint yet]
26-Jul-2014 09:38:17.683 UasSession 615 started
26-Jul-2014 09:38:17.683 Call from "Great Rm"<sip:[email protected]>;tag=1053633855 to <sip:[email protected]>;tag=9537e461
26-Jul-2014 09:38:09.757 Line 10001 got Device: Dev(6):[sip:[email protected]:5062 / 10001]
26-Jul-2014 09:38:09.731 Line 10000 got Device: Dev(4):[sip:[email protected]:5060 / 10000]
26-Jul-2014 09:38:07.663 Currently active calls [none]
