MyDocuments - 3CX MyPhone.log - can we move it please
Discussion in '3CX Phone System - General' started by JohnGrenfell, Mar 28, 2012.
  1. JohnGrenfell
    May 18, 2010
    6
    Is there any control under as to where the MyDocuments\3CX MyPhone.log file is located? In our environment My Documents both redirected and limited on size.
    I'm concerned that some users have no homedrive space remaining so my have problems when the log cannot be written to and that we backup this location every 4 hours and will get an increase it data churn due to a log file which should probably reside in %TEMP%
    Thanks,
    John
