MyPhone 24hr time format...
Discussion in '3CX Phone System - General' started by patrickrivard, May 31, 2011.
  1. patrickrivard
    patrickrivard New Member
    May 29, 2008
    100
    How can you change the default time format in MyPhone to the 24Hr format?
  2. willow
    willow Member
    Mar 1, 2011
    471
    my system shows as am/pm and not 24 hour format.
  3. patrickrivard
    May 29, 2008
    100
    This does not help...
    Mys system also shows am/pm format but I need to know how to make it 24hr....
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    815
    49
    Change the language at Preference tab to anything else, except English. :roll:
  5. patrickrivard
    May 29, 2008
    100
    Wow... who had such an idea..... I'm speechless....
    First, thank you for the response! it does change it!
    But, this is completely out of wack... this means that if you speak English you do not use the 24hr time format and viceversa... this makes no sense at all...
    Well some one at 3CX dev must redo their homework... This has to be user selectable!
    Or even simpler base on the computer clock...
    Thank you
  6. oedlan
    Nov 3, 2008
    18
    I agree.
    Please revise this 3CX Dev team
  7. nbailey
    nbailey Member
    Jan 31, 2011
    359
    The time in MyPhone shows system time from your machine. If your machine is not properly setup for 24 hr format then this will not display in MyPhone. Check your system settings, as mine is US English 24 hr format and it works no problems. In most English formats in Windows it is set to display time as HH:MM:SS tt if you change this to HH:MM:SS it will switch to 24 hr format not caring your language setting.
    Thanks,
    Nate
  8. oedlan
    Nov 3, 2008
    18
    That does not work, at least not for me.
    Confirmed this with Kevin in Stockholm last week.
    These are my settings, does not work for 24 hrs clock in MyPhone
    [​IMG]
  9. oedlan
    Nov 3, 2008
    18
    This is now solved at least for us. A 3CX tech connected to our PBX and applied a patch, now myPhone displays 24 hrs clock.
