MyPhone and Outlook Integrataion
Discussion in '3CX Phone System - General' started by joshhough, Sep 19, 2011.
  1. joshhough
    Feb 22, 2011
    72
    Hi there,
    I've just got involved with an existing network running SBS 2011, is there a way i can get MyPhone and the outlook integration available for all users? i want MyPhone to start on login.
    The problem i'm getting is if i install it, regardless of whether the computer is logged in as administrator, the program is unavailable for the other users (or the administrator) after the computer has restarted, nor do the outlook tools work.
    Thanks,
    Josh
