MyPhone can't call
Discussion in '3CX Phone System - General' started by ZenMasta, Sep 14, 2012.
  1. ZenMasta
    ZenMasta New Member
    Mar 10, 2010
    174
    I can't use MyPhone to create calls, return calls, or play VM on phone.
    However it can create a conference call no problem...I've tried with 2 extensions and 1 external number it seemed to work just fine for everyone.
    Seems like if it can do a conference call the rest would be just as simple.
    All phones are configured as remote extensions.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,416
    277
    What is the setting in the bottom left corner of the MyPhone screen set to?
  3. ZenMasta
    ZenMasta New Member
    Mar 10, 2010
    174
    There is nothing in the bottom left corner.
    If I try to play a vm on phone, my phone will light up briefly saying
    Answering
    PlayFile
    Then it will go back to ready after about 2 seconds.
  4. craigreilly
    Feb 1, 2012
    3,416
    277
    Ah - so you are not on v11?
    Sorry - can't help you much as I was never on v10 or prior.
