MyPhone Client - custom extension monitoring
Discussion in '3CX Phone System - General' started by messedupmojo, Apr 8, 2012.
  1. messedupmojo
    Apr 7, 2012
    We are looking at the 3cx phone system for a large(ish) implementation of about 400 users - we would deploy the myphone client to most of our users. The system they have at the moment allows then to add a custom list of extensions to their myphone equivalent - like a list of frequent users they dial - is there a way of doing this in myphone???
    So far i've read http://www.3cx.com/blog/myphone/monitoring/ - and it looks like you can see all extension information - but it would be useful to just subscribe tot he status of a few frequently used extensions
    David
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,554
    300
    Sounds like a great idea.
    I don't think you can... but submitting to 3cx.ideascale.com would be great.
