MyPhone Crashes consistently
Discussion in '3CX Phone System - General' started by pstulac, Jul 8, 2011.
  1. pstulac
    Jul 8, 2011
    21
    I have an issue on multiple computers where MyPhone crashes everytime the settings tab is selected.
    The error is:
    Microsoft Silverlight Out-of-Browser Launcher has stopped working.
    Both computers are running windows 7 with the latest updates.
  2. pstulac
    Jul 8, 2011
    21
    The issue seems to be resolved by uninstalling and reinstalling the desktop components.
  3. pstulac
    Jul 8, 2011
    21
    This still seems to occur randomly...I would say there is a bug in myphone somewhere.
  4. willow
    willow Member
    Mar 1, 2011
    471
    I had this happen a while back and it ended up being that outlook was open when i installed myphone. i had to uninstall myphone and reboot. make sure outlook was closed completely and then reinstall myphone.
  5. pstulac
    Jul 8, 2011
    21
    Thanks for the response willow, I will continue to monitor. Installed SP3 and as there are many fixes for myphone crashes I am hoping one of those fixes keeps the issue from reoccurring.
  6. nbailey
    nbailey Member
    Jan 31, 2011
    359
    This issue is not fixed yet but there is a work around for it. Go into the management console and the extension details.
    uncheck hide extension details in MyPhone. Relaunch MyPhone and it will be fixed.
    This is known and in works.
    Thanks,
    Nate
  7. pstulac
    Jul 8, 2011
    21
    I think you are referring to a different issue...the issue you are referring to started with SP3. This issue occurs when desktop components are installed, is random, and occurred prior to SP3.
