MyPhone desktop/CRM installation issues, SideBySide errors
Discussion in '3CX Phone System - General' started by mcbsys, Jun 16, 2012.
  1. mcbsys
    mcbsys New Member
    Oct 8, 2008
    171
    14
    I've recently installed 3CX 10. Then on my Win7 SP1 x64 box, I installed the MyPhone local desktop components (version 10.0.24018.2322) and the CRM Integration Module. I'm doing this in order to develop a custom CRM module, so I didn't want to install Outlook integration, nor did I want to install an existing CRM plugin. I encountered these issues:
    - When installing the CRM integration module, I didn't check any plugins. Then the module would not start because the following folder did not exist: "C:\Program Files (x86)\3CX CRM Integration\Plugins". I had to re-install with one of the plugins selected even though I will not use it.
    - The MyPhone integration installation did not offer the option of not installing the Outlook plugin. However when I started Outlook, it asked if it was okay for the 3CX plugin to install, and I said no. Now I am getting the following error in the Application event log:
    Code:
    Log Name:      Application
    Source:        SideBySide
    Event ID:      72
    Task Category: None
    Level:         Error
    Keywords:      Classic
    User:          N/A
    Description:
    Activation context generation failed for "C:\ProgramData\3CXMyPhone Client Addin\3CX Outlook Addin\3CX Outlook Addin.dll.Manifest".Error in manifest or policy file "C:\ProgramData\3CXMyPhone Client Addin\3CX Outlook Addin\3CX Outlook Addin.dll.Manifest" on line 4. The element asmv2:clrClassInvocation appears as a child of element urn:schemas-microsoft-com:asm.v1^entryPoint which is not supported by this version of Windows.
    These issues are not stopping my work but 3CX might want to fix them in future versions.
    Regards,
