Myphone displays caller stuck to IVR for 2 hours already
Discussion in '3CX Phone System - General' started by it2pimp, Jun 30, 2011.
  1. it2pimp
    May 19, 2011
    26
    There is a caller that was connected to an IVR number.
    In the management console there is no caller connected. But in Myphone (with admin rights) it displays a caller that is already connected for 2 hours now. While actually he isn't connected anymore, I cannot see his number on the trunk connected. We even called the number to check if his phone was still ringing (it is).
    How can I remove the caller that is stuck on the IVR ?
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Restart the phone systemm. Do you have SP1.1 installed?
  3. it2pimp
    May 19, 2011
    26
    I only can restart the phone system tonight (because it is currently in use) I was going to try that.
    But I wanted to know if there is another possibility to do this without restarting the phone system.
  4. nbailey
    nbailey Member
    Jan 31, 2011
    359
    nope that is the only option. So after hours do it, also be sure you are up to date with SP1.1
    Thanks,
    Nate
  5. it2pimp
    May 19, 2011
    26
    the 3CX phone system is up to date with sp1.1
