MyPhone empty Phonebook tab
Discussion in '3CX Phone System - General' started by chiyau, Aug 25, 2011.
  1. chiyau
    Aug 25, 2011
    5
    I have just noticed our MyPhone application does not show any entries in the phonebook, although the application will filter entries when you type names in the dialer.
    Is there a fix or is this a know issue?
    Chi Yau
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    What phone book are you talking about? In MyPhone you have two options, personal and company phone book.
    If you haven't setup a personal phone book this will be blank. There are no known issues with the phone book
    at this time, you might want to double check your settings on this.
    Thanks,
    Nate
