MyPhone Functionality Issue
Discussion in '3CX Phone System - General' started by Dntcg, Jun 16, 2011.
  1. Dntcg
    Jun 16, 2011
    I am having issues getting the MyPhone to work as intended.
    It will connect properly using the Ext/Pin, but it wont display the extension and call status. It shows every Ext as gray, and available, including a phone that is not even plugged in. The Ext I am using is a member of the management group, so it has full permissions. And I have also tested it locally on the server itself, so I doubt it is a firewall or networking issue.
    I am at a loss. Any help would be greatly appreciated.
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    This is not a functionality Issue - I assume you are using the Free Edition of 3CX?
