MyPhone Interface for users
Discussion in '3CX Phone System - General' started by jsmack79, Aug 10, 2009.
  1. jsmack79
    Jul 31, 2009
    12
    The MyPhone web interface won't work on my system.
    I'm using 3CX 7.1.7139.
    This is on a Windows Vista Pro machine using Cassini.
    It is the commercial version of 3cx.
    When i try and get to the MyPhone application from the server computer, http://localhost:5481/myphone, i get the following:
    Configuration Error
    Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
    Parser Error Message: It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS.
    Source Error:
    Line 155: by Microsoft that offers a single logon and core profile services for member sites.
    Line 156: -->
    Line 157: <authentication mode="Forms">
    Line 158: <forms cookieless="UseCookies" defaultUrl="UserMain.wgx" enableCrossAppRedirects="false" loginUrl="Logout.aspx" name="myPhone" protection="All" requireSSL="false" slidingExpiration="true" timeout="10"/>
    Line 159: </authentication>
    Source File: C:\ProgramData\3CX\Data\Http\Interface\myphone\web.config Line: 157
    I can't even see the error when I'm using a different computer... as though MyPhone isn't available to other machines.
    Thanks.
  2. jsmack79
    Jul 31, 2009
    12
    Here's more information from the Event Viewer on my XP business machine:
    Log Name: Application
    Source: ASP.NET 2.0.50727.0
    Date: 8/10/2009 1:45:05 PM
    Event ID: 1310
    Task Category: Web Event
    Level: Warning
    Keywords: Classic
    User: N/A
    Computer: 3cx-PC
    Description:
    Event code: 3008
    Event message: A configuration error has occurred.
    Event time: 8/10/2009 1:45:05 PM
    Event time (UTC): 8/10/2009 5:45:05 PM
    Event ID: 36c5b46254de48e7a76694f510106d08
    Event sequence: 6
    Event occurrence: 1
    Event detail code: 0
    Application information:
    Application domain: 641638e8-3-128943997780422433
    Trust level: Full
    Application Virtual Path: /
    Application Path: C:\ProgramData\3CX\Data\Http\Interface\
    Machine name: 3CX-PC
    Process information:
    Process ID: 4080
    Process name: UltiDevCassinWebServer2a.exe
    Account name: NT AUTHORITY\SYSTEM
    Exception information:
    Exception type: ConfigurationErrorsException
    Exception message: It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS. (C:\ProgramData\3CX\Data\Http\Interface\myphone\web.config line 157)
    Request information:
    Request URL: http://localhost:5481/MyPhone/index.aspx
    Request path: /MyPhone/index.aspx
    User host address: 127.0.0.1
    User:
    Is authenticated: False
    Authentication Type:
    Thread account name: NT AUTHORITY\SYSTEM
    Thread information:
    Thread ID: 17
    Is impersonating: False
    Stack trace: at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
    at System.Configuration.BaseConfigurationRecord.GetSectionRecursive(String configKey, Boolean getLkg, Boolean checkPermission, Boolean getRuntimeObject, Boolean requestIsHere, Object& result, Object& resultRuntimeObject)
    at System.Configuration.BaseConfigurationRecord.GetSection(String configKey, Boolean getLkg, Boolean checkPermission)
    at System.Configuration.BaseConfigurationRecord.GetSection(String configKey)
    at System.Web.Configuration.RuntimeConfig.GetSectionObject(String sectionName)
    at System.Web.Configuration.RuntimeConfig.GetSection(String sectionName, Type type, ResultsIndex index)
    at System.Web.Configuration.RuntimeConfig.get_Identity()
    at System.Web.HttpContext.get_ImpersonationToken()
    at System.Web.ClientImpersonationContext.Start(HttpContext context, Boolean throwOnError)
    at System.Web.HttpApplication.ThreadContext.SetImpersonationContext()
    at System.Web.HttpApplication.ThreadContext.Enter(Boolean setImpersonationContext)
    at System.Web.HttpApplication.OnThreadEnterPrivate(Boolean setImpersonationContext)
    at System.Web.HttpApplication.ApplicationStepManager.ResumeSteps(Exception error)
    Custom event details:
    Event Xml:
    <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
    <System>
    <Provider Name="ASP.NET 2.0.50727.0" />
    <EventID Qualifiers="32768">1310</EventID>
    <Level>3</Level>
    <Task>3</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2009-08-10T17:45:05.000Z" />
    <EventRecordID>712</EventRecordID>
    <Channel>Application</Channel>
    <Computer>3cx-PC</Computer>
    <Security />
    </System>
    <EventData>
    <Data>3008</Data>
    <Data>A configuration error has occurred.</Data>
    <Data>8/10/2009 1:45:05 PM</Data>
    <Data>8/10/2009 5:45:05 PM</Data>
    <Data>36c5b46254de48e7a76694f510106d08</Data>
    <Data>6</Data>
    <Data>1</Data>
    <Data>0</Data>
    <Data>641638e8-3-128943997780422433</Data>
    <Data>Full</Data>
    <Data>/</Data>
    <Data>C:\ProgramData\3CX\Data\Http\Interface\</Data>
    <Data>3CX-PC</Data>
    <Data>
    </Data>
    <Data>4080</Data>
    <Data>UltiDevCassinWebServer2a.exe</Data>
    <Data>NT AUTHORITY\SYSTEM</Data>
    <Data>ConfigurationErrorsException</Data>
    <Data>It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS. (C:\ProgramData\3CX\Data\Http\Interface\myphone\web.config line 157)</Data>
    <Data>http://localhost:5481/MyPhone/index.aspx</Data>
    <Data>/MyPhone/index.aspx</Data>
    <Data>127.0.0.1</Data>
    <Data>
    </Data>
    <Data>False</Data>
    <Data>
    </Data>
    <Data>17</Data>
    <Data>False</Data>
    <Data> at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
    at System.Configuration.BaseConfigurationRecord.GetSectionRecursive(String configKey, Boolean getLkg, Boolean checkPermission, Boolean getRuntimeObject, Boolean requestIsHere, Object&amp; result, Object&amp; resultRuntimeObject)
    </Data>
    </EventData>
    </Event>
  3. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    You may wish to try and use IIS, I never seem to have an issue with it like I do Cassin.
