myphone language
Discussion in '3CX Phone System - General' started by aly@accendo.dk, Sep 22, 2011.
  1. aly@accendo.dk
    Jun 15, 2011
    22
    We have just upgradet to servicepack 3 and was happy about the danish language support in myphone. But Im facing a problem. When we change the language the settings are not saved, after myphone has been shut down we have to change it agein.
    Does anyone have the same problem?
    Alex
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi Alex, when changing languages you need to hit apply or OK.
    In this case Myphone will exit and when you start Myphone again - myphone will load the new language file which was requested.
    Thanks and Regards.
  3. aly@accendo.dk
    Jun 15, 2011
    22
    Thanx for the advice. I think I have a corrupt installation. On another computer the myphone shutsdown after changing the language. But on this computer the language just changes.
    I have reinstalled myphone but with no luck.
    I will test further...
    Alex
  4. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Try and uninstall Silverlight and install again - it might fix your issue.
  5. aly@accendo.dk
    Jun 15, 2011
    22
    I have tested this over a periode. I have one machine that does not save any informations in the myphone interface.
    If I change the language on another computer the windows changes after cliking OK - nothing happens on this machine.
    I have
    Removed 3cx myphone, removed silverlight. Search the registry for 3cx entries. Deleted myphone folder. Restarted the computer and installed 3cx myphone agein. But the problem is still there.
    Does anyone have an idea for a sollution?
    Alex
