MyPhone "Lite"
Discussion in '3CX Phone System - General' started by Mullenlaw, Jan 6, 2012.
  1. Mullenlaw
    Apr 13, 2011
    53
    We have recently implemented v10 and it's going well. But our users are idiots. :O
    We like MyPhone but we want to find a way to keep users out of certain features.
    Is there a way to turn off some features?
    What we really want is just Conference Room stuff and VoiceMail and dialing.
  2. networkers
    Jul 1, 2010
    9
    In the 3CX admin you have the option to turn MyPhone features off for the user.
    Go to "extensions", select a user, select the tab "Other".
  3. Mullenlaw
    Apr 13, 2011
    53
    Yes, but I'd like to turn off more....
    I think every tab should have a checkbox. :shock:
  4. brandnewbie
    Jan 20, 2012
    My options are greyed out (I'm currently using the free version)! Is there anyting else I need to do?
    Thanks in advance!!
  5. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    You will need the paid version to access all features. unless you use the full featured demo however that is only good for 2 cc's.
  6. brandnewbie
    Jan 20, 2012
    Sounds good!! Thank you!!!
