MyPhone Logging Out Without Warning
Discussion in '3CX Phone System - General' started by samacmcbride, Nov 30, 2011.
  1. samacmcbride
    Aug 15, 2011
    5
    I've started to notice that some of our users are being logged out of the MyPhone web interface without warning... Users used to be able to stay logged in permanently. Did this change? Is there a setting that I can adjust?
    Thanks!
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Web server recycles every morning so no in V10 you have never been able to stay logged in all the time unless you removed the scheduled job. Are you up to date with SP4? Any issues with this had been resolved in the previous service pack.
    Thanks,
    Nate
  3. samacmcbride
    Aug 15, 2011
    5
    Thanks Nate. I have not updated to SP4 yet (planning on doing this later this week). Are you saying that SP4 addresses this issue?
    Currently, within an hours time, a rep will be automatically logged out multiple times–an issue that I hadn't seen until this week. They do log in every morning as you mentioned, it's the mid day log outs that I'd like to avoid.
    Thanks for the help.
    Sam
