MyPhone not reconnecting after PC resumes from hibernation
Discussion in '3CX Phone System - General' started by Lukas, Oct 10, 2012.
  1. Lukas
    Jan 23, 2011
    45
    Hello all!
    We have a problem with MyPhone V11. Some of us do not shut down their PCs, but hibernate them overnight. When the PCs are brought back the following happens with MyPhone:
    -- the interface is responsive, which makes you think that you are successfully logged in
    -- even the clock shows the correct time
    -- however the status of the extensions is frozen: who was available remains available, even if not, and if someone was on a call when the PC was hibernated, the call is reported to be still in progress (and maybe lasting for 10 hours or so...)
    My question: is it possible to make MyPhone "refresh" its connection to the server after a PC is resumed from hibernation, without having to exit MyPhone and restart it?
    Thank you very much in advance for your help!
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    Re: MyPhone not reconnecting after PC resumes from hibernati
    Do you have abyss or IIS web server?
  3. Lukas
    Jan 23, 2011
    45
    Thanks for your interest, Mixig. We are currently using IIS.
