MyPhone not working on Windows 8 64bit
Discussion in '3CX Phone System - General' started by afropulse21, Dec 5, 2012.
  1. afropulse21
    Mar 30, 2009
    Can someone confirm if MyPhone is supported in Windows 8, 64 bit? Keep on getting errors when installing.
    10,758
    286
    The current MyPhone may have been tested on Windows 8 Beta, since that has been in release for a while,but, I'm not sure. It would surprise me if it didn't work, as Microsoft seems to have made 8 backward compatible, at least for running applications. Visually, it's another matter.
    What sort of errors are you getting?
    Have you tried on more than one machine running Win 8?
  3. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    Works fine on 10 of my Win 8 pro systems
  4. afropulse21
    Mar 30, 2009
  5. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    Whan web server are you using? Abyss has some problems with Win 8. With IIS MyPhone is working perfect with Win8 64 bits.
  6. afropulse21
    Mar 30, 2009
    Using abyss.......will re install 3cx with iis
  7. markshehan
    markshehan New Member
    Nov 14, 2012
    141
    You have to use V11 with SP2 included for Windows 8 and Server 2012 to work best out of the box.
    I believe that upgrading an old box to Win 8 will keep it working but a clean install of 3cx will cause the problem you are having.
    V11 with SP2 included is in the latest download section
  8. mylove4life
    Jan 7, 2010
    165
    That's spot on, I just went thru that today and that what it was...
