Myphone port 4515
Discussion in '3CX Phone System - General' started by mixig, Jul 6, 2013.
  1. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    can someone tell me for what exactly myphone is using port 4515. I see on the blog: Port used for Data communication for MyPhone. But i didnt noticed any problem when there is only port 5000 is alowed through firewall.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    Mixig, I have not looked but perhaps is has something to do with when the desktop components are installed versus web only?
