myphone portal does not display properly in google chrome
Discussion in '3CX Phone System - General' started by stuart.rendall, Sep 28, 2010.
  1. stuart.rendall
    May 26, 2010
    25
    We have discovered using Google Chrome browser, from a PC, to view the myphone web pages, that the 'table' used to display records in 'incoming calls' , 'outgoing calls', 'voicemails', appears to contain no data - only the correct number of rows are shown.
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Re: myphone portal does not display properly in google chrom
    Chrome is not recommended to use with 3CX.
    To access My-phone & Web Management you will need IE or Firefox.
    What you can do is to install Chrome Plus -http://www.chromeplus.org/
    Google chrome plus can change to IE mode. So if you want to use 3cx with chrome you just need to change page to IE.
    Thanks and Regards.
