MyPhone sort by last name**IMPLEMENTED
Discussion in '3CX Phone System - General' started by agilis, Apr 22, 2011.
  1. agilis
    Aug 12, 2010
    19
    I have checked the box under PERFERENCES - SORT EXTENSIONS BY NAME but after i check the box I'm not getting any other option to choose last name or first name. Is this a bug with beta 2 or am i missing something?
    [​IMG]
    Also is there a way to sort them in columns and not one long list?
    Is there also a way to expand the viewing pane for the extensions?
  2. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    Re: MyPhone sort by last name - V10 Beta 2
    Check again with RC version we released couple of days ago.
    At the moment columns are not available but we will add them in the future. Together with expanding features to enable viewing of more extensions on screen. These will come later on.
  3. clarityscg
    Oct 16, 2008
    17
    We are having difficulty with changing back from Name Sort to Extension Sort.
    Any suggestions?
  4. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    You should disable the checkbox, log out of the myphone and log in again.
    if this does not work, you might check again clearing the silverlight cache. If this does not work, clear the browser cache. Changes from 1 version to another at this point might leave some old dirty cache which might cause conflicts in display.
  5. agilis
    Aug 12, 2010
    19
    Will the columns come with the final build of V10 or will it come in a later update?
  6. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    Final build will not have this. It will be in some later build as some redesign and resolution detection is needed for this to work neatly.
