MyPhone "The current account has been disabled" or "blocked"
Discussion in '3CX Phone System - General' started by oakley, Oct 31, 2012.
  1. oakley
    Aug 10, 2012
    19
    If a user gets their login details wrong 3 times in the MyPhone login process they get the message that either their account has been blocked or disabled and to contact the administrator.
    How can the administrator un-block or enable this for the user?
  2. mixig
    mixig Active Member
    Dec 13, 2011
    523
    12
    Re: MyPhone "The current account has been disabled" or "bloc
    In 3cx management console select that extension, go to tab "Other", under the Extension options check the option "Disable Extension"
  3. sigrunloa
    Jan 28, 2013
    Hello, I get this error on a new extension, but the "disabled" option is not marked on the extension. Any other suggestions on how to unblock the extension?
    Best regards,
    Sigrun
  4. mixig
    mixig Active Member
    Dec 13, 2011
    523
    12
    Is that extension blacklisted in 3cx? In 3cx console -> Settings -> Security -> IP Blacklist
  5. jochanan
    May 12, 2011
    12
    We have the same problem. We installed mopre 3cx pbx, but fot the first time, we created a new extension, when we tried to login in the myphone, we get the error that the account has been disabled.
    In the settings everything is OK. The ip adress also not blacklisted.
