MyPhone v10 - Minimize on Startup
Discussion in 'Windows' started by dsnyc, Oct 17, 2011.
  1. dsnyc
    Aug 30, 2010
    34
    How do we set the new v10 MyPhone to minimize on startup (ie: go onto the system tray)?
    The old 3CX Assistant in x9 had this option.
    Thanks.
  2. dsnyc
    Aug 30, 2010
    34
    I spoke to 3CX Tech Support, and this can NOT be done.
    Someone has this listed as a feature request for 3CX.
    PLEASE vote on it!
    Thanks.
    http://3cx.ideascale.com/a/dtd/V10-Myphone--Hide-When-Minimised-/133583-9854
  3. efounco
    efounco New Member
    Sep 28, 2011
    148
    Yeah. The only thing it seems to remember is if it were maximized or not. The physical size of the window, it's start up position and the layout of the rows/columns, etc. are all reset to default.
    I've even gone as far as trying to use a 3rd party program to correct the limitation without success (Ultramon).
    I'd really like the ability to seamlessly integrate it with a second touch screen monitor...
