MyPhone v11 - Not Responding when Shutting down computer
Discussion in '3CX Phone System - General' started by snowsam, Feb 5, 2013.
  1. snowsam
    May 26, 2011
    79
    Does anyone else have this problem and have a potential solution?
    Background: We are running MyPhone with our v11sp4 install. This problem is not specific to sp3. It is existed before.
    The MyPhone program is running on a Window 7 client.
    Problem:
    When shutting down the computer at night an immediate pop-up from windows is triggered that says 3CX MyPhone is not responding and do we went to terminate the process or wait.
    The problem can be avoided by closing MyPhone before initiating the shutdown (right click on notification area --> exit). However, this should not be required. I should be able to do a normal windows shutdown and have the program close on its own without delay.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    I have run across the issue before, but not with 3CX...other programs. You can look at the Windows event logs under Administrative Tools in control panel and then applications for clues. Most of the time it is has been an underlying program that is not shutting down that is used by the program being reported as the culprit. There may be a corrupt file. I have had good success in simply uninstalling the reported application and then reinstalling. You might try this
