MyPhone Voicemail**DISCUSSION
Discussion in '3CX Phone System - General' started by claxtro, Apr 2, 2011.
  1. claxtro
    Mar 12, 2011
    22
    Love the new portal design for MyPhone utilizing Microsof Silverlight. I am able to access the voicemail via the extension...this feature is great, but am unable to access locally on computer for remote access when away from extension. Is this just my computer or please advise. Thank you.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,110
    143
    Re: MyPhone Voicemail
    Hi - thank you for your feedback.
    You are expecting to access the voicemails locally on your client machine? Because the voicemails are not stored there. Those are stored on the server where 3CX Phonesystem is installed.
    Am I understanding you correctly?
  3. claxtro
    Mar 12, 2011
    22
    Right, I believe in version 9 of the Assistant when we went to voicemail, the voicemail could be played locally on the computer. The only way to hear the voicemail in V10 is through the (play on phone) option. Is there a way to download the voicemail locally so it can be heard on the computer or am I missing something? If this is the case, then the only way to get voicemail when away from the desk (or extension) is through the softphone? Thank you.
  4. nb
    nb Support Team
    Jun 7, 2007
    2,110
    143
    I understand what you need. Yes you are correct. Open on ideas.3cx.com.
  5. claxtro
    Mar 12, 2011
    22
    Just downloaded the beta2 v10 and it has the local play feature now on the computer...yeah!! Thank you to whomever is listening...or reading in this case! :D
  6. nb
    nb Support Team
    Jun 7, 2007
    2,110
    143
    Good - We are scavenging the forums and taking notes of what community wants. If it is easy we do it before final release. if not we leave it for one of the service packs. But if we agree internally with it we will implement it.
    Thanks for the update
  7. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Where do you see "play locally"? My only option is to play on phone.
  8. nb
    nb Support Team
    Jun 7, 2007
    2,110
    143
    Install locally. this only works on install locally because of silverlight security restrictions. Let me know if you have any problems.
