MyPhone & windows 8
Discussion in '3CX Phone System - General' started by patrickrivard, Nov 2, 2012.
  1. patrickrivard
    patrickrivard New Member
    May 29, 2008
    100
    There seems to be a problem with the MyPhone app and Windows 8
    Every time that we start MyPhone it closes by itself after just a few seconds...
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Backup your 3CX system.
    Uninstall it completely.
    Download the latest 3CXPhoneSystem11.exe, containing SP2.
    Install it and restore your backup.
    MyPhone will update automatically, be patient or reinstall it.
    Regards
  3. patrickrivard
    May 29, 2008
    100
    installed the Update...
    Still have the same issue...
    Cannot use MyPhone with windows 8!!!!!!!!
  4. patrickrivard
    May 29, 2008
    100
    anyone at 3CX care to reply?
    We have paid for 3CX, but now that we have updated to Windows 8 we can no longer use it.
    At the very least it would be much appreciated to let us know when this is going to be fixed.
    Thank you.
  5. patrickrivard
    May 29, 2008
    100
    OK.
    I got it working now.
    The solution was that I deleted all "Silverlight" related files and the program itself. then I open MyPhone from a Browser and clicked on install locally. It reinstalled everything and started working again like before Windows 8... So I guess it was a "Silverlight" related problem...
    Hope this can help others...
  6. patrickrivard
    May 29, 2008
    100
    We rejoiced too fast...
    after one external call, it still does the same thing... it closes after just a few seconds... cannot use MyPhone!!!
    Back to square one...
    Need help, please!
  7. eagle2
    Apr 27, 2011
    1,085
    11
    If you have a support contract with 3CX, issue a ticket.
    No other idea, I'm also experiencing some problems with 2012 / 8.
    Regards
  8. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    In order to help you we need some MyPhone logs. Open your 3CX Phone System Management cosole, go to Settings->Advanced -> Custom Parameters. Search for MYPHONECLIENTLOGGINGLEVEL and set value to 3. Press Apply/ OK and go to Windows 8 machine and start MyPhone. After MyPhone is closing collect 3CXMyPhone.log from C:\Users\Dan\Documents\3CX MyPhone and post it here. Maybe we can trace the problem.
  9. patrickrivard
    May 29, 2008
    100
    As requested, from two different stations:
    [11/5/2012 11:45:01] Outlook running state changed. Running: True
    [11/5/2012 11:45:01] Client successfuly connected on HTTP duplex to server using endpoint: http://12.34.56.78:5000/myphone/AssistPubSubSrv.svc
    [11/5/2012 11:45:01] Client subscribe completed Successfully
    [11/5/2012 11:45:03] Client login Successfully
    [11/5/2012 11:45:03] Receiving data
    [11/5/2012 11:45:03] Submit completed for client with id: 10
    [11/5/2012 11:45:03] Group name: __MANAGEMENT__ added on polling duplex connection
    [11/5/2012 11:45:03] Group name: FAMILLE added on polling duplex connection
    [11/5/2012 11:45:03] Group name: MAISON added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 2222 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 2220 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 2221 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 2223 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 1324 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 1323 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 1000 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 2224 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 2225 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 1322 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 1321 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 1225 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 1223 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 1228 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 1221 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 1224 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 1227 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 1222 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 1226 added on polling duplex connection
    [11/5/2012 11:45:03] Extension number: 2222 updated on polling duplex connection
    [11/5/2012 11:45:03] Initialization process finished. Start displaying the data
    ______________________________________________________________________
    [11/5/2012 11:44:54 AM] Outlook running state changed. Running: True
    [11/5/2012 11:44:54 AM] Client successfuly connected on HTTP duplex to server using endpoint: http://192.168.1.10:5000/myphone/AssistPubSubSrv.svc
    [11/5/2012 11:44:54 AM] Client subscribe completed Successfully
    [11/5/2012 11:44:55 AM] Client login Successfully
    [11/5/2012 11:44:55 AM] Receiving data
    [11/5/2012 11:44:55 AM] Submit completed for client with id: 8
    [11/5/2012 11:44:55 AM] Group name: __MANAGEMENT__ added on polling duplex connection
    [11/5/2012 11:44:55 AM] Group name: FAMILLE added on polling duplex connection
    [11/5/2012 11:44:55 AM] Group name: MAISON added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 2220 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 2222 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 2221 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 2223 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 1324 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 1323 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 1000 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 2224 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 2225 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 1322 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 1321 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 1225 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 1223 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 1228 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 1221 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 1224 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 1227 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 1222 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 1226 added on polling duplex connection
    [11/5/2012 11:44:55 AM] Extension number: 2220 updated on polling duplex connection
    [11/5/2012 11:44:56 AM] Initialization process finished. Start displaying the data
    Let me know...
  10. danhriscanu
    Nov 29, 2011
    232
    Please try the following procedure:
    1. Backup your configuration with backup and restore tool.
    2. Uninstall everything from server. Check if everything is uninstalled including IIS.
    3. Install 3CX Phone System 11 SP2 from the beginning. Do not upgrade. Just fresh install 3CX Phone System 11 with SP2.
    4. Restore your backup and check if everything work.
    If this procedure is not working for you please open a support ticket and we will handle this.
  11. patrickrivard
    May 29, 2008
    100
    OK... I did the Back-Up, uninstalled, reinstalled, but cannot reinstall the Back-Up... it says "This is an unsupported backup. Please contact support"....
    Restore failed...Error: EOF in header
    now I'm completely fu....
    what can I do now...
    The Back-Up file is there it exist it is 1.72 Gb.... Even if I try to unzipp it or open it in windows it says that the folder is empty...
  12. patrickrivard
    May 29, 2008
    100
    Just finished reprograming everything in the system!!!!
    it now seems to be working with the W8 machine...
    Will test further tomorrow and post back...
  13. danhriscanu
    Nov 29, 2011
    232
    If you would like we can have a remote session to your server and check the problem.
    Download Teamviewer , install it and PM me the ID and Password to connect.
