MYSQL Extensions
Discussion in '3CX Phone System - General' started by adonias, Oct 13, 2007.
  1. adonias
    Oct 13, 2007
    7
    Call Logs x Day
    How to generate report for day?
    Any sugst?
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Generate monthly, export to Excel (CSV), sort by date will give you daily, and you can all sorts of great stuff with it. Just selecting CSV will open a new tab (in Firefox, why use IE?) to view the CSV file. You can copy and paste data by date if you wish, if just looking for data in a simple format. Can be run daily. Hope this helps.
  3. adonias
    Oct 13, 2007
    7
    work ok..
    other problem.
    need take this dates, and insert in mysql table.
    When i using msql_conect say:
    ??????? :shock:
  4. adonias
    Oct 13, 2007
    7
    Try copy "php_mysql.dll" in "\3CX PhoneSystem\Bin\Php\extensions".
    Apache logs error says:
    Edit mi php.ini in:
    Code:
    ;extension=php_interbase.dll
    ;extension=php_ldap.dll
    ;extension=php_mcrypt.dll
    ;extension=php_mhash.dll
    ;extension=php_mime_magic.dll
    ;extension=php_ming.dll
    ;extension=php_mssql.dll
    ;extension=php_msql.dll
    extension=php_mysql.dll        <----- add
    ;extension=php_oci8.dll
    ;extension=php_openssl.dll
    ;extension=php_oracle.dll
    extension=php_pgsql.dll
    extension=php_pdo.dll
    extension=php_pdo_pgsql.dll
    Any idea ?
  5. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    I have very little knowledge in this area I am afraid. I am hoping another Forum member will be able to provide help and I am tracking this thread so I can learn as well :oops:
  6. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    3CX uses Postgres as the database and not MySQL. Are you trying to create a new MySQL db? What db are you trying to do a msql_connect to?
  7. adonias
    Oct 13, 2007
    7
    Well.
    i need export all call logs to my web site for remote admin.
    My web site support only mysql. :p :p
    Thxx men
  8. BendyMetal
    Oct 8, 2007
    36
    Have you thought about allowing access to the 3cx server remotely - either ssh/vnc/https/something similar?
  9. adonias
    Oct 13, 2007
    7
    It is much more complicated, because I have three businesses, and would be a folly to be reviewed individually. The best way is to check across a single domain
