N95 Nokia WiFI
Discussion in '3CX Phone System - General' started by rorygennaro, Nov 7, 2007.
  1. rorygennaro
    Nov 7, 2007
    11
    I do not know how configure N95 with 3cx.
    My server is 192.168.1.1
    Can you hel me?
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    Try this.
    Create the extension for N95 in 3cx for example "100" and password: "100"
    after that enter the settings in your phone
    1. Go to "Tools" and then to "Settings"
    2. Go to "Connection"
    3. Go to "SIP settings"
    4. Add a new default profile
    5. enter the following settings:
    Profile name: 3cx
    Service profile: IETF
    Default access point: choose your WLAN access point
    Public user name: your extension@ip from your 3cx-server (Example: 100@192.168.1.1)
    Use compression: No
    Registration: Always on or When needed
    Use security: No
    Proxy server:
    Proxy server address: ip from your 3cx-server (example: 192.168.1.1)
    Realm: 3CXPhoneSystem
    User name: your extension (example: 100)
    Password: the password of your extension
    Allow loose routing: Yes
    Transport type: UDP
    Port: 5060
    Registrar server:
    Registrar serv. addr. : ip from your 3cx-server (example: 192.168.1.1)
    Transport type: UDP
    Port: 5060
    Now go back to "Connection" and then to "Internet tel. settings"
    create a new profile:
    SIP profiles: 3cx
    And then it hopefuly would work..
  3. alicic
    alicic New Member
    Oct 3, 2007
    119
    I used this configuration for Nokia E61 and it works,
    I think it should work with your mobile too ;-)
  4. Mori
    Mori New Member
    Mar 23, 2007
    223
    It should work with all mobiles with WLAN support.
    Have tested it on nokia N70, N81, N95, E60, E65, E70, 6500 and 9300i com.)
  5. rorygennaro
    Nov 7, 2007
    11
    Ok it connect but when I call it also fron intrenal it reply busy end close
    In mobile I receive a message call lost
  6. Mori
    Mori New Member
    Mar 23, 2007
    223
    What version and build of 3CX are you using?
    And what does the server logs say?
  7. rorygennaro
    Nov 7, 2007
    11
    Ok now run. Thank you.
    How I connect with the same N95 in external ?
    with the same configutation but with xxxxxx.dyndns.org in IP address, it non register.
  8. mbs1
    Mar 7, 2007
    35
    hi,
    I do not think that you will be able to use the N95 as an external extension as i do not believe there is any stun support within the Nokia firmware .
    it is possible via a vpn connection and i have tried this and it does work
  9. andyb
    Nov 15, 2007
  10. nokiafan
    Nov 15, 2007
    Hi, this is great, can you post your settings from your nokia?
  11. andyb
    Nov 15, 2007
    Domain Parameters:
    STUN Server Name: stun.3cx.com
    STUN server port: 3478
    TCP NAT Bind Refresh: 1200
    UDP NAT bind refresh: 1200
    CRLF Refresh: Off
    IAP Parameters:
    Select your WiFi IAP
    TCP NAT bind refresh: 1200
    UDP NAT bind refresh: 28
    STUN retransmission: 250
    Now on the E65 I've left the VoIP Services section empty as this seems to work for the IAP I use.
    I have used it in the past and it seems to work the same with or without
    If you do use one, make sure the "Secure Call Preference" is set to prefer non-secure and that Ignoring Domain Part is on under the profile settings.
    You can set the priority of the codecs aswell if you wish, if you do, make sure that iLBC is at the top.
  12. nokiafan
    Nov 15, 2007
    Thanks for your reply. that is how i have it set up too. Mine does not dont work and i belived i had it wrong...
    this is log when i try to make call to remote extenssion which does not ring at all.
    14:50:28.218 StratInOut::eek:nHangUp [CM104007] Call(231): Call from Ext.514 to 517 has been terminated by Ext.514; cause: CANCEL; from IP:192.168.1.1
    14:50:27.999 CallLegImpl::eek:nConnected [CM103001] Call(230): Created audio channel for Ext.514 (72.77.31.157:9452) with Media Server (192.168.1.103:7450)
    14:50:27.624 CallConf::eek:nIncoming [CM103002] Call(263): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:27.593 CallLegImpl::eek:nConnected [CM103001] Call(229): Created audio channel for Ext.514 (72.77.31.157:9450) with Media Server (192.168.1.103:7448)
    14:50:27.108 CallLegImpl::eek:nConnected [CM103001] Call(228): Created audio channel for Ext.514 (192.168.1.102:5004) with Media Server (192.168.1.103:7446)
    14:50:26.780 CallConf::eek:nIncoming [CM103002] Call(262): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:26.358 CallConf::eek:nIncoming [CM103002] Call(261): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:25.874 CallConf::eek:nIncoming [CM103002] Call(260): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:25.436 CallConf::eek:nIncoming [CM103002] Call(259): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:24.999 CallConf::eek:nIncoming [CM103002] Call(258): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:24.561 CallConf::eek:nIncoming [CM103002] Call(257): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:24.139 CallConf::eek:nIncoming [CM103002] Call(256): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:23.702 CallConf::eek:nIncoming [CM103002] Call(255): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:23.280 CallConf::eek:nIncoming [CM103002] Call(254): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:22.827 CallConf::eek:nIncoming [CM103002] Call(253): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:22.452 CallConf::eek:nIncoming [CM103002] Call(252): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:21.983 CallConf::eek:nIncoming [CM103002] Call(251): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:21.546 CallConf::eek:nIncoming [CM103002] Call(250): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:21.108 CallConf::eek:nIncoming [CM103002] Call(249): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:20.671 CallConf::eek:nIncoming [CM103002] Call(248): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:20.186 CallConf::eek:nIncoming [CM103002] Call(247): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:19.749 CallConf::eek:nIncoming [CM103002] Call(246): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:19.311 CallConf::eek:nIncoming [CM103002] Call(245): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:18.874 CallConf::eek:nIncoming [CM103002] Call(244): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:18.546 CallConf::eek:nIncoming [CM103002] Call(243): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:18.061 CallConf::eek:nIncoming [CM103002] Call(242): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:17.624 CallConf::eek:nIncoming [CM103002] Call(241): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:17.186 CallConf::eek:nIncoming [CM103002] Call(240): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:16.749 CallConf::eek:nIncoming [CM103002] Call(239): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:16.311 CallConf::eek:nIncoming [CM103002] Call(238): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:15.843 CallConf::eek:nIncoming [CM103002] Call(237): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:15.405 CallConf::eek:nIncoming [CM103002] Call(236): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:14.968 CallConf::eek:nIncoming [CM103002] Call(235): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:14.530 CallConf::eek:nIncoming [CM103002] Call(234): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:14.093 CallConf::eek:nIncoming [CM103002] Call(233): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:13.655 CallConf::eek:nIncoming [CM103002] Call(232): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:13.218 CallConf::eek:nIncoming [CM103002] Call(231): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:12.780 CallConf::eek:nIncoming [CM103002] Call(230): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    14:50:12.343 CallConf::eek:nIncoming [CM103002] Call(229): Incoming call from 514 (Ext.514) to sip:517@72.77.31.157:5060
    When i call from remote extenssion to my local extenssion i its one way audio in this case.
    14:52:51.530 MediaServerReporting::RTPReceiver [MS105000] Call(276) Ext.517: No RTP packets were received on 00000221@:remoteAddr=192.168.1.100:16384,extAddr=72.77.31.157:9046,localAddr=0.0.0.0:9046
    14:52:51.514 StratLink::eek:nHangUp [CM104001] Call(276): Ext.514 hung up call; cause: BYE; from IP:192.168.1.102
    14:52:19.030 CallLegImpl::eek:nConnected [CM103001] Call(276): Created audio channel for Ext.514 (192.168.1.102:5004) with Media Server (192.168.1.103:7042)
    14:52:19.030 StratInOut::eek:nConnected [CM104005] Call(276): Setup completed for call from Ext.517 to Ext.514
    14:52:19.014 CallLegImpl::eek:nConnected [CM103001] Call(276): Created audio channel for Ext.517 (192.168.1.100:16384) with Media Server (72.77.31.157:9046)
    14:52:05.343 CallConf::eek:nProvisional [CM103003] Call(276): Ext.514 is ringing
    14:52:05.218 CallConf::eek:nIncoming [CM103002] Call(276): Incoming call from 517 (Ext.517) to sip:514@sanel.dyndns.org
    i know i'm missing something but not sure what.
  13. rorygennaro
    Nov 7, 2007
    11
    For the external extencions you must do as follow:
    Extencion manage -> others
    Extension is External
    Bind to Media Server
    And now Work :D
  14. nokiafan
    Nov 15, 2007
    I wish,
    i had it set up as external extenssion before, i did try to bind it to media server and no luck, same thing happend when it was not bind to media server. one way audio still going on.
  15. f1piz
    Jan 7, 2008
    Can you explain me Realm: 3CXPhoneSystem because on my N95 is noted domaine which must I put? IP of the server 3CX?
    Thank you for your answer because that made several days that I seek and I do not find!
    f1piz
  16. simones181170
    Dec 4, 2007
    51
    i've got E65 and with the nokia software doesn't work
    with fring it work very well
  17. f1piz
    Jan 7, 2008
    Thank you for information I will test with this software
    best regards,
    stephane
  18. f1piz
    Jan 7, 2008
    Thank you for your answer.
    I tried to make it function with fring and still not solution to date somebody would have it a note of configuration of fring with 3cx?
    Thank you in advance for your answers.
    Greetings,
    Stephane
  19. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    does the fring setup finished ok?
  20. f1piz
    Jan 7, 2008
    yes the setup finish ok But I will remake tests of configuration
    stephane
