Name field in 3CX Client
Discussion in 'Android' started by Helmut72, Oct 27, 2017.
  1. Helmut72
    Aug 24, 2017
    13
    within settings, account there are 2 fields called "name" for an account, what is the difference between both?
    Thank you!
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    13
    Hello @Helmut72,
    Good question. Name and Display name are two different things. For, example:
    If you have multiple accounts on a single Android client and you want to distinguish between them then you can change the "Name" field to Office 1 (ext.100), Office 2 (ext.101), Office 3 (ext.102) and so on. If the phone will re-provision then the Name will stay untouched.
    The Display Name is the name of the SIP Account on PBX (Extention) and it cannot be changed because phone will re-provision on startup and it will replace the Display Name with name specified on the PBX.
    #2 Marios Neophytou, Oct 27, 2017
  3. Helmut72
    Aug 24, 2017
    13
    Thank you, but which is what? The Android App shows two field as "Name" and not one as "Name" and the other one as "Display Name". Both can be changed.
  4. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    What version are you running?
    Do you see these settings in your phone?
    [​IMG]
  5. Helmut72
    Aug 24, 2017
    13
    15.1.90 from 01.09.2017, latest according to Google Play. And no, it shows "Name" two times.
  6. LeonidasG
    Nov 19, 2008
    1,557
    118
  7. Helmut72
    Aug 24, 2017
    13
    Sure (both on Galaxy S6 and a fresh installation on Galaxy S8):
    Same with 15.5.143 (Beta from your link).
  8. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    It looks like a translation mistake. We'll check and we'll update this topic.
    Thanks for spotting it.
    vali
  9. Vali_3CX
    Dec 12, 2008
    1,527
    71
    Hi Helmut
    OK, I checked - in german translation file, both "Name" and "Display Name" fields are translated as Name, and this affects all clients, not only Android one. We will fix it - thanks again.
    vali
